Gfunk720
Hey everyone. I have a 2011 4500 that has had AC issues from almost day 1(13k Miles). It has been at the dealership at least 5 times and while they seem to band-aid the problem(for thousands of dollars) it doesn't seem to have ever completely corrected it. They have replaced the AC clutch, evaporator pressure sensor, and more. Needless to say, I'm a little hesitant to send it back over there and lose it for a while with little confidence that it will get fixed.
It had worked pretty consistently over the last 2 years though, and only in the last few months started working intermittently. It would work fine for a few days or hours, shut off when hitting bumps in the road, and work intermittently at start up. A few weeks ago it stopped working completely, and I can't seem to figure out why. I'm a little hesitant to start changing parts without knowing what exactly the issue might be.
1. Tested Freon levels with a real gauge setup- System is full and when it was working working blowing cold
2. I tested power at the relay, and found no power coming into the relay to go out to the compressor
3. The compressor seems ok, as if I jump power over at the relay it comes on.
4. One of the switch points on the fan speed selector already doesn't work, so I'm wondering if perhaps the A/C button on the HVAC control unit failed.
Does anyone have access to a wiring diagram for the HVAC system? I can't seem to find anything online, and even our chassis builder said he did not have access to it. I'd like to test to see if power/signal is getting coming off the HVAC control, but there are a number of wires off the control and I don't know what is what.
Has anyone else had the HVAC control unit stop working? Seems like that would be the culprit as it is the first thing upstream of the relay, but it could also be a wiring break or something. Just seems unlikely that a wire is damaged.
