Has the pan and valve covers been removed?
What was the extent of the dealee tear down?
Does the oil look chocolate brown?
Does the oil look black?
Your data,
4 OC since new
First @ 3k miles, factory fill PYB
2nd, 3rd,4th @ 6 k OCI with 5w20 M1
Current milage = 26594
So 26594 -(3k + 3x 6k)=5,594 miles on current oil
In my opinion 6k is too long an OCI for severe duty usage,as explained with 25 miles/ two week intervals.
put ~ 150 miles day on my 5.7 RAM, about 95% Highway with oil temperature at 213F.
Use PP, which is cleaner than M1 by 8%, dealer wants OCI at 5k for this engine.
These newer engines require cleaner oil than in the past, with smaller oil passages, smaller bearing tolerances,
It is possible that the oil filter relief valve could have stuck open, allowing the oil to bypass the filter media and build up free carbon in the oil.
The synthetic oils will run for longer periods because of less shear film damage due to refined molecular structure compared to group 2 conventional oil.
However, the synthetic oils still become contaminated with carbon, the same as conventional oil.
The challenge that oil filter folks have is to design an oil filter that will go the extended OCI of synthetics.
Fram Ultra XG series made for full synthetic oil uses a two layer media to trap carbon.
The spin on filter measures a whooping 3" dia x 3" length. The size of this filter is about 1/6 of volume if all other V8 I have had and still have.
The Fram PH8 was the standard size filter that fit most V8s and is huge compared to the 4th generation 5.7 Hemi V8.
The relief valve opens, maybe, in cold weather start up or after the filter media is fully saturated with carbon.
The cheap relief valve in the oil filter replaces the internal relief valve found in GM engines.
GM/Delco oil filters do not have relief valves.
The relief valves in oil filters are supposed to open at 8-10 psig.
After doing a whole bunch of research on current oil filters, some as designed for only conventional motor oil
Some are designed for both conventional and synthetic, while others are designed for only synthetic.
The two major differences in the design of oil filters.
One type incorporates the relief valve in the dome while the other type uses a thread end relief valve which is more expensive to manufacturer.
There are many types of filter media ranging from wood fiber to mico fiber synthetic glass.
The consumer does not know what the filter media is used, unless described on the packaging.
Short trips will produce more carbon/ mile, since engine had not reached steady operating temperature, where the combustion process is less efficient and produces more unburned fuel.
The recommended Morpar oil filter is made by Purulator which incorporates the threaded end type relief valve.
Most spin on type oil filters with relief valves are the dome end style, since it is less expensive.
Bottom line
Believe the NAPA oil filter failed with relief valve stuck open and as a result failed to trap the extra carbon produced from the short trips.
The Royal Purple and Fram ultra oil filters are really good filters for the 5.7 Hemi.
Oil filters are a non regulated industry as opposed to the oil industry.
Something needs to done to help consumers be able to select and compare the particle removal rating and reliability of different brands.
