2014 front ring gear not welded in!!!
TankNyc
Albany NY Area
Hello everyone. I just installed 35" mud terrains. I have 5,7 with 8 speed do i need to change gears?
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Need more info about your truck. First of all what gears do you have now? If you have anything except 3.21's you're OK. The 8 speed is gearing is pretty forgiving.
Jay
TankNyc
Albany NY Area
3.21 rear axle ratio and 235mm rear axle
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Its really up to you if you want to swap out to 3:92s, Ism sure it will run better after the swap and hold 8th gear better on the hwy as well.
You dont haft to be any means but it would be easier on the truck if you did.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
1500 to 2000gs. might look in junk yards and see about finding parts from wrecked trucks as well.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Thats what I was talking abput as well, if you dont have a LSD I would add that at the same time.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Check with Matt at Moe's for the price of a gear set and an install kit.
Jay
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
214-789-1110 or check his site on here--he is a vendor on this site
Moe's Performance
Jay
StoneDude76
West Chester,PA
So can you switch the gears out of the front diff if you have a 14? What is the clear answer?
Sent from my XT1080 using Tapatalk
Tdjma
is this 100% accurate?
my truck is a 3.21 truck but I would love the 3.92 gears.
I can just buy gears and have someone install them? without changing the housing like everyone says?
Yes
