Mikey593
Anyone know if it is possible to take a 2021 Ram 2500 6.4 hemi and put it into a 2014 Ram 2500 that had a 6.4 hemi in it?
Should bolt right in,but check the pilot bushing in the rear of the crank,the 6 speeds and 8 speeds use a differant crank bushing for the snout of the torque convertor.You could swap your sensors over,i might be wrong,but i don't think there was any change in the 6.4's sensors from 14 to 21Anyone know if it is possible to take a 2021 Ram 2500 6.4 hemi and put it into a 2014 Ram 2500 that had a 6.4 hemi in it?
Good call! If You have the 8 speed you will Want the A8 bushing or remove the one in the back of ur engine.Should bolt right in,but check the pilot bushing in the rear of the crank,the 6 speeds and 8 speeds use a differant crank bushing for the snout of the torque convertor.You could swap your sensors over,i might be wrong,but i don't think there was any change in the 6.4's sensors from 14 to 21
I think the sensors never changed on the 6.4's from 14 to 21,but if they did,just reuse the sensors from your 14 in the 21what about the computer (ECM) will it need to be changed as well? I thought I read somewhere that I might have to swap it out too? Thanks for your help too.
