2014 ram xpresskit problems.
17BlueStrkPearl
So i got the xpresskit remote start on my truck. It was working great until I disconnected the battery. Now my key fob will start the truck but i cant unlock it. I have to use the actual key. Then once i open my door it kills the truck. Anybody know if i have to reflash the dball2 to get it to work again right.
baum
savage, mn
2015 Laramie
the locks shouldnt have anything to do with the dball2. first see if the locks work when you disconnect the dball. 2nd if anything you may need to just go through the program steps like you did when you first installed it and not actually hooking it up to a computer to re-flash it.
BadRam14
Gilbert, AZ
I had the same problem with my 4X10. I tried to reprogram it but no luck. I took it into my local car audio shop and they said the brain was basically frozen and they had to reset it and reprogrammed it all. It has work fine ever since.
