2015 2500 6.4 towing/trans experience
SHOOT2KILL
2015...2500H.D.
thanks all for the input. as originally stated, the up hill in 4th gear wasn't really my issue, just an observation different than every other truck I've ever owned and buying a diesel to avoid this a few times a year isn't realistic.
the down hill engine braking with ever increasing RPMs in 2nd gear was my real issue/question. It engine braked just fine in 3rd with moderate RPMs and I really didn't need much or any brakes but if a car pulls in front of you and you touch the brakes, it goes into screaming 2nd gear mode. Didn't realize these motors didn't have a "redline" (good to know) but the gradually climbing RPMs to 6000 had me concerned.
not sure how I'd lug a motor going down hill but I do agree, redlining rarely causes issues. my concern was the damage that over revving could do, the exponential increase in stress /wear, etc. but I guess that's a non-issue now - thanks for the info mtofell.
^^BOLD...Please video tape the expression on your dealership service mgr's face when you tell him your truck engine blew up because it was reving @6k rpm on a downhill grade for almost 6 miles...BUT..."All my internet buddys @ ramforum.com said that it is normal and FCA engineered it to do this...LOOL
spoon059
Just north of Washington DC
6.7 CTD
Clown...
Mmaxed
ok, so this horse has been beat to death. the transmission is less than ideal. I've had such a miserable towing experience this week, I gotta ask. Is there an easy way to check for an update for the transmission factory programming? will the dealer let me know if there's an update?
This week, we took the 9000 lb travel trailer from Sacramento to Santa Barbara. Was in tow/haul mode the whole time. So, going over the mountains going UPHILL, the truck held onto 4th gear forever and wouldn't shift into 5th unless I actually slowed down from 55 to 50 or less. then I would have to very slowly build up speed again just so it wouldn't shift back into 4th. Ok, maybe not a big deal.
The bigger issue was going down hill. I assume these trucks have an incline sensor. down even a mild grade, touching the brakes immediately sends the transmission from 5th to 3rd at 55-60 mph. even with gentle roll on throttle, it won't shift out of 3rd. Add to this, if you even tap the brakes a second time, it shifts into 2nd, holds it until you hit a flat/level area. This means you are near redline, engine screaming, the entire way down the hill (6-10 miles long in this case). I tried switching out of tow/haul. nothing. I just had to slow way down and ride out the hill in 2nd until I hit bottom.
is this considered normal? anyone know of an update/flash?
You have hit on the reasons I don't use tow/haul. Touch the throttle a little and it pukes down 2 gears. Won't upshift until you let off.
On the down hill braking I just manually click down to the gear I want. Even then sometimes I have to ease into the throttle a little to get it to shift up a gear and not just build rpm. My Ford with a V10 did that too.
SouthTexan
408 CTD
Not what I wanted to hear. Getting ready to throw a sour 14k behind mine for a trip through the mountains on the east side of the country.
:eek:
loveracing1988
Clarkston, MI
I guess I don't understand the problem with 4th gear at 55mph when towing. It's not like it's running hi revs at that speed in 4th gear.
The downhill performance OP described seems odd. I haven't noticed that behavior when towing.
Dealer has flashed mine a couple of times. One of those times corrected an issues where tow/haul mode would bypass 3rd on downshift and go straight from 4th to 2nd. Now it will use 3rd gear on downshift in Tow/Haul mode.
I don't know how we can check if a newer flash is available. I would take it to the dealer and have them check.
I had half of the same towing issues as the OP when I towed a simple enclosed trailer a few months ago. In tow haul mode it would run in 4th no matter what I did, just sitting there revving. Now no that isn't necessarily a bad thing, but this was in all conditions, uphill downhill, headwind tailwind, it didn't matter it would run in 4th. If I disabled tow haul mode it would bounce back and forth between 5th and 6th gear. I put it in manual 5th and it towed just fine including up some hills telling me there was no need for it to be running in 4th. By enclosed trailer I mean one that weighs 2300 pounds, not exactly a 10k 5th wheel.
drittal
E. Montana
We don't need no stinkin' Cummins. 6.4 FTW :D
I like the the 6.4 too.
However, if he has sentiment that echoes the OP about RPMs, he will not like towing 14k in mountainous regions. He will see 4th, 3rd, 2nd, and likely 1st if the grade is steep enough. He will see extended periods of 4K+ rpm if grade is steep enough. He will want to take advantage of the engine braking when going down hill to help maintain speed.
tjfdesmo
AZ
My experience exactly. For the way it is programmed Tow/Haul is useless to me as I don't normally pull heavy enough to be stuck in fourth gear all wound out for nothing. Pretty poor setup, all in all.
On Edit: I will add that my buddy pulled my box trailer with his 1/2 ton, 5.7, 8 spd, 3.92 and in Tow/Haul it just pulled it effortlessly, and was in the right gear all the time, and without screaming and hunting. Pretty sad.
Danno
Mid Atlantic
2016 Power Wagon
coobie
S.Michigan
2022 Ram 1500 big horn
HvyDuty
Perrysburg, OH
5.7L
My experience towing my travel trailer with my old 5.7L 8spd vs. 6.4L 6spd was similar to your buddy. That 8 spd was great, always in the right gear. Power was no problem, however the tail would wag the dog with my 1500, even with a properly set up WD hitch and sway control. I was within all my weight specs too.
Even with the much less refined transmission, my 2500 just pulls and handles it way better IMO. Right tool for my job.
MN-Ram
MN
6.4L Hemi
I had a similar situation where I was towing my 6'x12' enclosed trailer at about 2500 lbs for a total of 110 miles. I called the service manager at my dealership to see if I needed to use tow/haul at that weight, and he told me to watch the transmission temps to make sure they didn't climb too high. He said the higher the temps, the more shifting that was going on with that light of weight. I towed the whole trip in regular drive mode, and the temp never went above 178 deg, according to the EVIC. The truck drove just fine. That was summer time too.
However, I was on fairly level terrain. I don't know what your situation was though.
loveracing1988
Clarkston, MI
I live in Michigan so pretty much the same as you only the biggest hills in my part of the state are overpasses.
SouthTexan
408 CTD
Speaking of Michigan.... Planning a trip up there to visit some friends and for the Woodward Dream Cruise later this year so I can finally scratch it off my bucket list.
Underarock13
Ram 2500 14
6.4 hemi
Guys I miss my 6.4! But I borrowed my dads 6.0 chevy Sunday to take the boat out and I hate to say it towed like a dream compared to my 6.4 with 3.73. 6.4 was much faster but the 6.0 tows much smoother due to gearing and tranny. Hopefully in a couple years 6.4 tranny gets an 8 speed and I will buy a new one ;).
cdhd2001
I have the opposite experience. My old piston slap 2001 6.0 4 speed auto 2500hd swore me off Chevy forever. Towing half the weight of a 5th wheel was a floor board stomping experience for 2500 miles.
My 6.4 tows my 14k 5th wheel like a dream compared to that truck. [emoji2]
Sent from my SAMSUNG-SM-N910A using Tapatalk
Danno
Mid Atlantic
2016 Power Wagon
Your comparing 2014 to 2001, a little difference
