Jwithing
Has anyone had issues with the front driveshaft cv joint boot splitting? I was under the truck a couple weeks ago changing out the Trans thermo bypass thingamajig and noticed grease all over my cross member and elsewhere. Realized it was coming from the front driveshaft. Looks like it has been that way for awhile. I'm not too upset about it as I already received a dorman replacement for about $360 that is coated black and I've always wanted to pull the shafts and coat with por-15 due to their obnoxious surface rust. I don't use 4x4 a lot, so I am surprised it's already busted with about 100k miles on a 2015. Just wondering if it may be due to the angle with the 6 inch lift and if there's anything I can do to prevent premature wear again.
Also for anyone's reference the rubber boot that goes over the slip yoke to transfer case is called transfer case output shaft boot. I couldn't find it teying to search driveshaft boot and had to go to the dealer to ask. I've got a new one on order and plan for the swap once that comes in.
