2017 2500 leveling kit
gtex1970
texas
which Bilsteins are recommended for the 2017 Ram 2500 to level the front end?
once level, what are the limits for height/width on tires using stock 20" wheels? and what offset works well for aftermarket wheels?
I see a lot of information out there for the 1500s but not as much for the 2500s.
thanks,
greg
G. Mcpherson
Yacolt, Wa.
2023 Ram 2500 CC SB Tradesman
They make a 5100 for lifted Trucks. The Shocks do not lift the Front end.
Ratket
Arizona-
Depends if you are going aftermarket springs or spacers. The spacer kits utilize a extension for factory shocks. I think the Hellbent steel “ spacer kit” comes with proper billstins and doesn’t use a shock extension bracket. Once lvled if proper back spacing is used you can stuff a 37 under there.
Edit -
The 2500”s are spring and shock, not cool over like the 1500”s. That may be where your confusion is.
wallacemf
2500 4x4 Hemi 6.4
Do the spacers clunk around and make noise every time you hit a bump?
MADDOG
Out Exploring Arizona
Nope, mine are quiet as a mouse over bumps. My kit also has a shock relocation bracket which helps with keeping proper shock geometry. I've used this kit on 3 2500 Rams and am very pleased with it.
Sandbox
Warrenton, VA
6.4 HEMI
MADDOG, which kit are you using?
MADDOG
Tuff Country P/N 32909
Gear Jammer
Yacolt WA
Cummins
The spacers I used bolted to the spring bucket, no chance of movement with them. They looked like the Tuff Country P/N MADDOG listed, but I can't remember who made them for sure.
Dmopar74
I used the rough country kit, they bolted on
gtex1970
gtex1970
texas
thanks. rough country kit is on the way!
wetsquirrel
Bilstein has a few leveling kits available for the 2014-2018 Ram 2500. Below are the PN's:
2" Gas / 5100 series shocks / PN- 46-268655
2" Gas / 5160 series shocks / PN- 46-268662
2.3" Diesel / 5100 series shocks / 46-241641
2.3" Diesel / 5160 series shocks / 46-263889
CajunRamit
Houma, LA
2017 Limited
Cummins 6.7 L
6AB6FB70-14DE-405B-A72A-423AB66D7B64.jpeg The salesman told me I had a 2” lift on front and 1” on rear of my 2017 2500 Limited 4x4 SB looks very level to me.
ICE888
Seatle
Cummins 6.7
I used fabtech dirt logic setup. 2.5 spacer up front. The spacers from fabtech just looked beefier than any spacer available. Will include pictures when I have chance.
thanks
