2018 Ram 2500 Cummins stock headlight problem
jmant230
Hello, had a strange issue last night. My headlights would not work. No low beams no high beams. None of the positions on the selector make any difference.
The headlights do light when I hit the unlock button on the keyfab. It was a cold evening in the high 20's
Anyone experience this issue?
Thank you,
Jamie
Hugh Johnson
FL
6.7 cummins
Do they work now? If so, probably just a glitch. Either way you should take it to the dealer. There may be a software update or some other fix. Headlight issues are prime for a recall if other people are having the same issues.
jmant230
jmant230
Thank you Hugh, I think that is what I will do.
mtnrider
Georgia
Never heard of anyone having this issue before? Keep us posted what you find out.
jmant230
jmant230
Thank you for the replies. I was able to get the lights to work. This problem is related to a snow plow installation about 2 months ago. I unplugged the plow light harness from the Upfitter harness and the lights came back on. Not sure why this is happening now as I have not been using the plow and there is no load. It is a Snowdogg plow. I will check the fuses and relays and contact them tomorrow.
