I've been doing a bunch of research into which travel trailers we'd be looking at buying. Recently went to an RV show and found a few models we were interested in, but the one we really want is about 35.4' total length. Reading this forum, I've come to the realization that this might be a bit too long for a rookie to towing and RV'ing.
I'm curious to see if anyone had any thoughts on this setup for towing a 32' travel trailer:
'14 RAM 1500 5.7L 6.4' bed, 149.5" wheelbase
3.92 gears
Factory 4 corner air suspension
18" wheels w/ Load: E rated tires
ProPride 3P hitch
The concern here is sway, really, as we'd ideally like to go on long trips.
Travel Trailers I'm looking at have are in the neighborhood of 5-6000lbs dry weight, with hitch weights of 5-750 lbs.
My thoughts, which are not based on personal experience, is that with the wheelbase of my truck, the tires, and the hitch, I -should- be okay with a 30-32ft trailer.
Should I scale down my expectations to only 30ft and below, or would that set up be okay with 32?
3.92 gears
ProPride 3P hitch
