33s on stock wheels.
Camblanton
Mount Holly NC
Okay. 2016 Tradesman came stock with 17in wheels. Swapped to 20s and 33in tires. Now they rub when i turn hard right or left. Is that normal?
crazykid1994
What’s the tire dimensions? Factory is only 33x11.5 I think. Factory rims?
sm10
2016 Power Wagon
If they are factory rims then 33s should definitely not be rubbing unless you were maybe running 12.5" wide tires...then maybe you'll rub.
Express SN95
Maryland
They shouldn't be rubbing, but my only guess is that the Tradesman came with "standard" ride height which might sit lower then say an Express, Big Horn, etc. :shrug:
billdozer79
Ohio
I'm running 12.50 33's on stock 20's with no rubbing on a BigHorn. So I think Express is right. It's my first Ram so I'm still learning about these things too.
RoadRamblerNJ
Knoxville, TN
392 Hemi
Running stock 275/70-18 (roughly 33.5") on my 2017 Tradesman 2500 6.4. Is yours a 2500 or 1500?
Sent from my SM-N910V using Tapatalk
Gary2
S Jersey
Most 1500s with the 20" wheel on the Express models like mine came with Raised Ride Height listed on the build sheet . That and the stock tires were 275 -60 -20 not 70s. 70 would be a taller tire the stock .
