37s with front leveling kit
YammyMonkey
2014 1500 Laramie
I have a 2014 with the stock 20" wheels and would like to go a little bigger on the tires. Would I be able to run 37 12.5s with just a front end leveling setup, say the Bilstein 5100 shocks?
Currently on 275/65R20s.
I'd like to get as much ground clearance as possible without getting into a big, possibly expensive, lift project.
I looked around and didn't see this particular combo addressed, which is probably a clue.
G-Ride990
Administrator
Administrator
Chandler, AZ
What size tire are you running now? Doubt you could make 37x12.5s work.
I somewhat recently bought new tires for my truck. Went with 35x11.50s, just a little smaller than my last set at 295-65r20.
I also have zone ucas and bills at 2.8. My old tires rubbed a tiny bit at times... Enough to wear a hole in my inner fenders over the life of the tires though.
Don't think you could stuff 37s in there imo.
mrack
The width alone will cause rubbing on the UCA, you would need spacers or offset wheels. It could be possible but not practical, and only with a lot of trimming.
Y
YammyMonkey
2014 1500 Laramie
Current are 275/65 20s. Updated the OP.
Lowrider357
