Trey Higgins
So I am thinking about swapping from the 4th gen 5 lug to 5th gen 6 lug. The adapters are sketchy so I would rather do a full conversion.
From my research, It appears that all I need is a 5th Gen rear axle (with the same gear ratio obviously), 5th gen hubs, and 5th gen rotors. I believe that the 4th gen calipers should work with the 5th gen rotors as well as the rear axle. The CV axles should also work with the 5th gen hubs. The 5th gen rear axle should also have the same mounting points for control arms etc.
Does anyone have more info about this? Anything I have wrong? Suggestions?
