6.4 intake swap on 5.7
Matthew Smith
Georgia
I have acquired a 6.4 hemi intake from a wrecked truck at work. I want to swap to swap it out on my 5.7. I know I need a EGR block off plate, injector spacers and a wiring harness extension. Is there anything else I would need. Also where do I need to run the hoses since the 6.4’s are setup differently
Matthew Smith
Matthew Smith
Georgia
Can I also run the 6.4 throttle body or do I need to swap it also
Throttle bodies are identical. All 2013 and newer 5.7's /6.4's including the 485 horse car 6.4's all use the same 251 throttle body. You'll need a differant airbox,i'd also look into replacing the intake O-rings.Search CrazyKids posts,Khris already has a write up on swapping the 6.4 manifold.
Matthew Smith
Matthew Smith
Georgia
I’ve seen som me of his post I’m still confused on where to run the brake booster vac line and evap stuff
