6.4 Truck engine
M
Mike Wenrich
Mariposa, Ca
2004.5, 2023 RAM 2500 Laramie 4x4
5.9 Diesel, 6.4 Hemi
Hopefully I can get a 6.4 in a 3.4 4WD crew cab Laramie in 2024. Saw on the news this morning that it's likely the big 3 will be hit with a strike next month unless they meet union demands. That might mean fewer trucks built and price gouging by the dealers. I can't seem to get a break from higher prices and less value for my retirement dollars. Some of the trucks are built in Mexico so maybe those won't be affected.
Tulecreeper
Sthrn AZ
So true. Click bait is the name of the game there.
For us, it's because we almost entirely use the truck to do truck stuff. Bring bulky stuff home and tow trailers. We have a Hybrid car that we do all of our local running around with, and even some of our longer drives. Heck of a lot cheaper to replace that every few years than my truck or the wife's new Pacifica.
My 22 will be a year old in October and I just rolled over 7K with it. Hoping it's another 20 year truck for me.
My 2000 Silverado 1500, bought in Oct 1999, lasted me over 23 years. Had 190,000 miles on her, and very few issues in the 2+ decades. It was my ED driver and did good by me. I was actually going to go with a Chevy 2500 this year for my new truck, but they wouldn't let me order one - I had to take one from the lot. All the trucks on the lot were waayyy more truck than I wanted or needed, so Chevy lost my business. The manufacturers need to go back to allowing the customer to pick and choose and order what they want. Building a vehicle with every conceivable bell and whistle on it, then telling the buyer, "It's all or nothing," is going to bite them in the end.
jejb
NW Arkansas
I didn't believe you so I had to go to RamTrucks dot com for myself.
What's even weirder is that it shows the "only option" (oxymoron if I ever saw one) for an engine is the Cummins, at a price tag of $9,695.
That makes sense since there are only 2 engine options to begin with in the 2500's. Take one of them away and your options get pretty slim.
TestPilot57
Vermont
Right. But then it's not an "option".
Travelin Ram
I noticed when shopping last year that all the Laramies were diesel. I didn’t do any research because I wasn’t shopping that trim level anyway.
It’s not an unusual marketing ploy to only offer top trims with the most expensive engine. I’m sure I’ve seen GM and Ford doing it.
Example from last year the Chevrolet ZR2 was only available with a premium fuel sucking 6.2.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
6.2 is a no-go engine.......they added AFM / DFM / PFM to it, and never fixed the oil pumping aspect of it with their low tension piston rings.
No way I'd go back to the engine I dumped in 2011 for the same design in 2023.
hemihustlin
Montreal
my work neighbor now has a 22 gmc 1500 at4x 6.2 with what im assuming is a borla atak cat back ( his usual go to for trucks)
sounds great for a Chevy, almost as nice as my truck haha but you can now hear the 10 speed stumbling at low speed
im sure it drives fine but its no where near as smooth sounding as our 8 speeds
Lsujker
Baton Rouge
Not driven the 10 speed 2500 GMC but have spent some time in the 1500. Actually very nice. My opinion better than the 8 speed hemi 1500. ZF does not shop for gears as much but the GMC is eager and always in the right place. The older 6 speed 6.4 2500 has a bad wrap but drives well.
hemihustlin
Montreal
like you said I would have to drive one. have driven the ford 10 speed and it is very performing but i dont prefer it overall
tron67j
Maryland
That is nutty. Wonder why they did that. It really crushes the ability to tow with it, a Limited with the diesel engine has around 2k of payload, subtract about 500 pounds for people, gear in truck and hitch, and using a 15% pin weight and the max trailer is about 10k pounds. Without anyone in the truck the maximum trailer would be about 13k pounds, well below the 19k " maximum towing " Ram lists for the truck I looked up.
You would have to be towing 2 axle hay trailers in a road train to use that maximum made-up number towing that Ram advertised.
tron67j
Maryland
My 6 speed 2500 tows like a champ through mountains on East Coast and anywhere else I go. Don't want to start a discussion war here but would wager that problems can be sometimes associated with upper level GCWR and/or trying to do 75 all the time.
Lsujker
Baton Rouge
Figured I would give my 6.4 hemi experience. Purchased new and still currently own a 2017 ram tradesman with the hemi. Low miles at 55k. Truck has been great. Tow my jeeps few times a year. Random towing inclosed trailers and misc items. Most long drives include few times a year across states with my family. Fuel economy sucks and ride is harsh but drives well and has been reliable. Turn mds off every time. Would like to drive the 8 speed as they say it adds the performance missing but she paid off.
Issues with rear end locking up but salved with fluid change. Had an engine light misfire once at full throttle but all seams to be well. Great truck/motor combo. If I towed 7k more often or up and down mountains, no question I’m going diesel. 6.4 has to work at that weight but can do it. Temps run low so no worries. Not buying ford even with 7.3. Fords are num, squeaky, problematic and service here sucks. GM about the same and the interior is new but missed the mark. GM finally center the steering wheel with the seat. Kudos.
HEMIMANN
Minneapolis, MN
6.4L HEMI
I wish I had more confidence in the 6 speed RFE transmission, in our case the 66RFE. All we know we learn from member experiences and those aren't statistically analyzed with the entire population of these in use.
Certainly getting rid of the trans oil cooler thermostat helps reduce heat-related oil deposits in the trans. Also using premium synthetic trans oil does the same. Keeping out of overdrive while towing, and using the tow shifting mode program to keep rpms up (out of low rpm shifting, gas-saving mode) are all known transmission longevity measures.
What we don't know is whether these are good enough to extend RFE trans life to 'expected' lifespan (200k miles, I would posit). We just.......don't know.
I'm a little less concerned about the Hemi engine since I switched oil to Red Line exclusively early on, and change every 5k miles. It's a proven tick reducer and killer. That actual data has been reported on here. But not RFE transmission life data.
tron67j
Maryland
I have been reading about the red line use, 5w 30 I think, correct? I have only used PUP but do change every 5k, may switch to redline after I use up remaining oil.
For the transmission, I have read of problems here or there but without data it is hard to know where the problems are originating. For example if one puts big tires on the truck without upgrades to the transmission, etc. but still launches like a 10 second racer, one tends to have problems. Modifying the truck requires other upgrades or a change in one's driving habits. This is why I don't plan to worry; I will use the truck as it was designed and if I have a transmission failure then I rebuild it with better parts. In my years of driving with near a million miles under the belt I have replaced a transmission, flushed a few, rebuilt or replaced alternators and starters, and replaced a clutch among many fixes. It happens, mechanical things can break.
Could the transmissions have been built to handle more abuse, certainly but at a cost to everyone. I imagine there are millions of these transmissions out there and don't see evidence of millions of failures.
Lsujker
Baton Rouge
Would highly recommend not using 5w30 in the 6.4. Manual specifically states 0w40. Assuming Ram spec'ed a 0 weight oil at startup for a reason. But like you i stick with pensoil ultra every 5k miles. It will tick for 3 seconds on startup sometimes. So did almost all other modern vehicles I have owned.
My 6 speed runs at 169 deg. max when towing on 35" tall tires. If she goes, its not due to heat. The 1500 ZF runs 10 to 15 deg hotter with no load. Wonder what others have experienced.
jejb
NW Arkansas
Word was that 90% of the 2 Limited 2500's were ordered with the Cummins anyway. And Mopar/Steallantis has been trying to cut down on the number of options for years now. We ran into that when we got the wife's 21 Pacifica.
Yeah, that's the dirty little secret about 2500 CTD's, forced on us by the 10K limit the government puts on them. I knew that going in, but I also know I live within the legal limitations. The answer there, if you're going to haul heavy, is to get the 3500+.
ramffml
ramforum
There is a 5 degree C difference in the spec between a 0w and a 5w. Yes, 5 degrees. 0w is good to -40C (-40F) and 5w is good to -35C (-31F).
What do you think is thicker. A 5w starting up in the summer at 68F, or a 0w starting up in the winter at -20F?
OasisNinjaBat
