6 spd questions
wannahdawg
I've searched as much as I could, but couldn't find definitive answers.... Somebody tell me about the 6spd behind the HEMI. Model number, good/bad, etc...I see a lot of people complain about it, rather have the 8 spd, etc but I also see the opposite. I've got a 13 express CC 2wd, tow about 2500-3k lbs daily monday-friday with it, in the Appalachians and don't have any issues so far...80,600 miles...I'd like to take care of it though so if anybody recommends stuff, clue me in...
Hemi395
Cape Cod MA
The 6 speed is the 65RFE. It's not a bad transmission it's just not as nice as the 8speed.
The good thing about the 6 speed is it's serviceable. The filters and fluid can be changed like any other transmission and the fluid is relatively cheap. There are some aftermarket pans that have drain plugs for easy draining.
The 8 speed fluid is $40/quart and the filters are integral to the pan so the whole pan needs to be replaced and it's $350 from the dealer.
The bad things about the 6 speed are if you do a full throttle kickdown at highway speeds it *can* kill the trans. Other thing is with the Hemi it's pretty much at its capacity. Other than that, it's pretty reliable.
Personally I like my 6 speed. I opted for it over the 8 speed simply because I plan on keeping my truck for awhile and I wanted easy/cheap maintenance.
Hope this helps!
DILLIGAF
Canada
I just had to pay to get the new software updated. Now thats ******... I figured if they had new software for it it would be a nice freebie...lol...
I dont really like the 6 speed, But I have learned to live with it.
W
wannahdawg
Thanks for the post Austin, really helped me out.
Hemi395, that was what I was looking for, I been wanting to do the servicing myself because I do plan on keeping the truck. AND I use it as a truck. I have the 3:55 gears and have no trouble towing. It does what I need it to, and it does it well. I don't plan on modding for HP gains etc, nor do I hammer on it.
DILLIGAF, what's this s/w upgrade you speak of?
AustinB
Banned
San Diego, Left Coast
Misread the question. Don't have any good info to contribute... I traded in my 6spd for the 8 and wouldn't think twice about going back.
Seems like it works for your payload/needs, enjoy.
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Who the heck's brilliant idea was that ????
and how will full throttle kickdowns kill it ??
Hemi395
Cape Cod MA
Yeah, no idea....
That's what I've read about the 6 speed is that the 4th gear clutch pack is the weak link as is the 3rd gear or in the 545RFE 2ndPrime...
Kytow
WOT downshifts into 4 and WOT up shift into 4 (130 mph) are what kill the 6 speed. I believe someone said its due to the spacing between some of the clutch packs.
Sent from somewhere with confusion.
Hemi395
Cape Cod MA
That's what it was, I knew it had something to do with wot and 4th gear...
TRCM
USN, Retired
Newport News, VA
Well, ain't gotta worry about that in a stock crew cab 4x4.
rocket800
2012 Laramie
I don't mind my 6 speed either! How are you guys servicing yours? Mine is due and I'm torn between dropping the pan/filter change vs complete flush.
Kytow
I'm going to do mine at 30,000 miles. I believe I'm just going to drop the pan and change filter.
I'm also looking into changing the torque converter, probably wait until then. Trying to decide if I want to try and do it or pay a pro.
U&A
2016 3500 SRW
6.4 HEMI
Well ill never have to worry if that is what causes it. im to much of a :baby: and think my truck has emotions. I dont want to hurt her feelings. :buffer:
Hemi395
Cape Cod MA
I just changed my fluid and filter at 22000miles. If you do a pan drop every 30000 or so you shouldn't need a flush. I certainly wouldn't go the Chrysler recommended 120000 miles before changing the fluid...
Kytow
I try to avoid WOT down into 4th. But 2-1 WOT is fun
W
wannahdawg
Well I bought mine at 65k, and it has 80340 now. You recommend I go ahead and do a filter and fluid change? I did plugs, PCV, air and cabin filter at 75k...
Hemi395
Cape Cod MA
I would. Does the fluid still look red? Shift ok?
TRCM
USN, Retired
Newport News, VA
Not here.....I mean, I do baby her, but I also smack her backside from time to time.
4 yrs old & <17,000 on her so far
Hemi395
Cape Cod MA
Damn I thought I had low miles at 22000 and 3.5 years old...
Ftank
