buckeyexx
- Jan 25, 2015
- 686
- 711
- Location
- Ohio
- 2016 Power Wagon
- 6.4 Hemi
Like the title says I have the sonnax line pressure booster installed. Ive had it installed in for a week now and I can say I feel it does very well when the trans is under heavy load or heavy acceleration. It will firm up the shifts and feels not as soft going through the gears. You don’t notice much under normal acceleration. Do think it is a total game changer? No I don’t but I think it helps with some of the soft feeling shifts the rfe has. It maybe even better if the truck had a trans tune not sure. I believe it is for most of the rfe transmissions and just plugs right in to the side of the trans where you line pressure sensor is located. So it’s just plug in booster to The sensor and then plug the truck side into the booster. 2 minute job.
I did this upgrade because I’m getting ready to upgrade the valvebody to the sonnax universal unit. I’m hoping in conjunction with this and the valvebody I will achieve better and smoother or firm up the shifts that the rfe is lacking and cure my hard downshifts I’m experiencing.
