- Apr 28, 2012
- 23,318
- 45,104
- 2010 Hemi Reg Cab 4x4
- Hemi
People say moving from the different summer/winter blends is a decrease in mileage and that is less btu difference.
The increase in fuel economy can probably attributed to the higher octane as much as to the lack of ethanol in the 91E0. I don't think I've ever seen a Lexus where 91 wasn't the recommended octane. We have 88 E15 here for .05 less a gallon than E10 87. I've bought it a couple of times and couldn't tell any difference in the fuel economy between it and 89 E10.Never messed with it on my truck but my wife’s Lexus IS350 gets 347 miles on a full tank (according to the onboard computer) on regular 87 octane w/ethanol, but gets 421miles on 91 octane ethanol free.
My truck got exactly the same mileage on E85 as it did on regular. I am not lying or telling a tall tale. I know that it should not be, but it was. I was as surprised as anyone.btu on various fuels
gas 114,000
e10 111,800
e85 81,000
No the engines aren't the same on various fuels, as everyone with flex fuel vehicles know, the gas mileage is way way less. here is edmunds test. Trucks that get 18 mpg on gas, get 12 mpg on e85, and the other tests similar results. Maybe e85 should be the future, but let's not tell tall stories about it. I'm not big on subsidies, but maybe farming (especially meat production) and e85 should be subsidized these days.
Incidentally even pure petroleum (and e10) fuel in Arizona has two separate blends based on the geographic latitude at which they're sold, since the Northern half of Arizona has a higher average elevation than the Southern half of Arizona. This is also done to keep evaporative emissions below established standards and reduce incidence of vapor lock on older carburated vehicles with a draw type fuel system.
As of 2014 we were consuming around 4.5 million gallons of gasoline a day in the valley according to the document.
I'll dump what I may or may not know into this conversation. Dad had a 2001-ish Blazer. It ate fuel pumps. Mechanic who I went through automotive classes with in college told him that pump didn't like ethanol blends as it lacked the lubricity of non-ethanol. So living in Oklahoma he could buy the good stuff at Love's. Right now my daily drivers are GM. I dump 2oz per 5gallons of Marvel Mystery oil into the tank. I have non-ethanol available down the street. I buy it for my weedeaters, and my Husqvarna 21hp Kohler. The E10 makes then run leaner and will in time damage the engines. It will eat the fuel lines from the inside. The gas cap has a "no E10" emblem on it.
I used to run Citgo ethanol blended premium in my 1981 2.2 Dodge Charger. The vapor lock was such a problem that it go to dying going down the interstate. The factory Holley didn't like it at all. I read a FSB at the dealer and they said, "no ethanol blends!" For a while I was carrying a bottle of rubbing alcohol to dump into the carb to start it when it didn't have enough time to cool. (yes I know it has water in it)
1993 Toyota Corolla. 1.8lt. 11.75:1 compression. Factory manual said 87 octane is fine no need for higher octane due to the design of then engine. E10 was okay, don't go to E15 or beyond. I did some testing with it. Ran E10 87, E10 93, 87 straight gas which came from the Marathon bulk plant. It was sold "non-branded" at the local convenience store so I'm not sure what additives were in it. I ran the non-ethanol 93 too. I got better mileage going up in octane, and going non-ethanol. Figuring the cost per mile for fuel at that time no matter what I ran it figured out to $.08 per mile in fuel costs. Now that is a "primitive" EFI and computer system VS the newer stuff. It still had a distributor
My daily drivers are Buicks. '97 Lesabre, and a '05 Lesabre. Both 3.8's. The '05 gets 2-4mpg more with real gas according to the in dash display and it runs pretty true to the calculator/odometer. I run the Marvel Mystery oil in them. I have the repair bills for the '97 and saw a bill for fuel pump replacement before 100K. I got the '05 from dad at 82K on the clicker. It is at 198K and still has the factory pump. The MMO lubes the top ring on the pistons, and lubes the injectors. Supposedly keeps them clean too.
Your E85 Flex fuel vehicles have different components in the fuel systems for the alcohol amounts. The pumps are different. I have heard (no scientific proof) that E85 vehicles get worse mileage on E10 than non-flex. I don't know any with a flex car or truck.
I was a fuel hauler for a short stint. E10 eats the O-rings we used with the delivery hoses. The black O-rings were that way. We had green colored ones that lasted longer. The polycarbonate "sight glass" on the loading heads would yellow, crack and leak. We always had to replace them. On a humid day the in ground storage tanks needed to be capped of quickly so as to not suck water out of the air. Ethanol and water will combine and sink to the bottom of the tank. Ethanol fuel is actually heavier than non. When the water and E sink to the bottom of the tank you can be left with 76-78 sub octane gas on the top. AFAIK all gasoline is 78 octane or so before they dump additives and ethanol into it.
Anything you have that is carbureted needs to have the rubber hoses replaced with fuel injection hoses with the proper clamps. Ethanol eats them from the inside.The diaphragm in your fuel pump(?) Keep an eye on it. Never use plastic see through fuel filters! It will crack them.
I have a 72 Duster I am going to bring back on the road some day. I may go EFI.
The only Ethanol free fuel that I have access to is 87 octane. Is it better to run 87 octane Ethanol free than 89 octane with ethanol?
The v6 is the only engine in the trucks thats E85 Compatible
Parts include: e-85 compatable injectors, E85 o rings on injectors and all fuel connections, a larger fuel pump as it will require alot more volume, plastic fuel lines ethanol and non coated steel don't get along. Possibly a sensor in the tanks or lines that can detect which fuel is being used depending on mfgr And an ecm/pcm flash for the correct fuel injection rate, timing and ignition curve.My 2011 4.7 is E-85 Flex Fuel. I have the Flex Fuel badge and the yellow fuel cap. I wonder what is different as far as engine parts that makes it a flex fuel and/or if those parts are better or worse for general longevity with regular E-10 or E-15.
That leads to some fun correlations, 4.5 million gallons of gasoline (ignoring diesel?) contain a little over half a trillion BTU's so spread across the roughly 15000 square miles the Phoenix metro area covers that's around 35 million BTU's per square mile per day of heat or around 1.5 million BTU's per hour per square mile. A normal 1500 watt space heater converts around 5100 BTU's per hour so that's the heat equivalent of around 280-300 space heaters per square mile distributed evenly throughout the city and operating continuously, or equivalent to if you placed half a billion such space heaters in a grid roughly every 300 feet across an area as large as Switzerland and just left 'em running.
I have a friend on the Moparts forum that built a 318 with a carb and built it with E85 as a steady diet in a '69 Barracuda. Running a 273 2bbl cam, 850 Thermoquad, Magnum heads, lots of compression, headers full length exhaust with no mufflers. He was a mad scientist. 29-31mpg with 2:73 gears. I lost track of him when he moved from TN to MT.Hi. I'm new here. I have a 2008 ram 1500 with E85. After reading the above. I'm glad I have that engine. I got it used in november. In my name is the date I got it. E85 is really nice in it. When it's not cold. I read the warning about it grabbing water. So it got cold. I tried regular. Not good. Acceleration on the 4.7L V8 was just not there. So next tank I tried the middle stuff. Still the pep was not in its step. I bit my tongue and put premium in. Then it ran like E85 was in it. Thought. Well that's not affordable. My concern is how it performs not MPG. So my last experiment worked. I got cheap octane boost and put regular 87 in. I got what the tank of premium did. The E85 stations are few and far between. So winter mix now is the regular with a bottle of octane booster. I thought the engine might be dirty. New to me old truck. So I put some engine cleaner in that I use that is also a lubricant. It didnt like it at first. That's Lucas cleaner. Then after a drive everything got back to normal. I think it needed it. All around the engine does great. It just needs more octane. With my driving being almost all highway. I live in corn ville. So its rural and the highway connects everything. If their is a rise in ethanol coming. I'm glad I got this engine. In the nicer weather the savings on E85 makes it well worth it. I did a MPG on E85. I got 18 MPG. That's with enjoying my first big truck with a big engine. So I think it could go up. Unless it likes to race. Past I had SUVs. I know never again. This truck is a lot better. I think this is the right section because of ethanol talk.
