A/C help??
cdferry
My A/C seems to be stuck on defrost and it sounds like the compressor is still running a while after i turn the key off.
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Pretty simple...
Check your vacuum lines going back to the cab on the passenger side for cracks or leaks. The HVAC will default to DEF mode when the vacuum system fails as a safety measure.
As for the compressor it should stop instantly after the key is shut off. You might be hearing the freon balancing back out equalize in the system which is normal.
Orca
