ABS/BRAKE lite come on every so often????
RamV10
Western Central NV
V10
On my 99 Dodge QC 4x4 V10 5 speed I don't drive it much but every so often I will start it & the ABS/Brake lights come on. If I shut it off & restart it they go out.
I have replaced the rear ABS senor in the rear end a few years ago. I had new front brakes & rotors installed a year ago. The truck only has 87,000 miles. It was & is used for pretty much nothing but towing.
Brakes work fine.
I'm thinking a dirt connection???
Thanks in advance.
Stegs
1998 Dodge Ram 1500 4x4
5.2L 318 C.I.
Brakes work fine.
Thanks in advance.
the abs sensor you replaced is the speed sensor correct?
I just had to do this also on my truck.....replaced it with a napa part and its been working fine ever since
You may have a loose/bad connection. take it apart, clean both ends and see if that helps
also check your brake fluid. If its dirty you may want to change it.
Crocdocs
Central Florida
The sensor in the rear diff isn't the abs sensor I don't believe... They should be at the wheel end of the axles like on the front hub and I think they are inside the drums if it has rear drums. The sensor in the diff is the vehicle speed sensor that reads your speedo
Crocdocs
Central Florida
On the front and rear axle just follow the only wires that go down towards the wheel lol. My truck is a 2000 with ABS on front but my axles are older so they do not have ABS so no connecting the wires. My ABS and BRAKE light stay on all the time.
Stegs
5.2L 318 C.I.
my brake light came on and then my abs
I drove for a few more miles then i lost my speedo and odometer
I replaced the speed sensor in the rear differential and it fixed all four issues
the speed sensor must have something to do with the abs/brake light
Crocdocs
Central Florida
Yea I'm sure it does because the abs probably needs the vehicle speed to help. But on the front there should be one sensor at each Hub
Stegs
5.2L 318 C.I.
that could be
but the symptoms described by the OP sounds like what i had!
Just giving my advice on what i think it is based on what i had too
RamV10
RamV10
Western Central NV
V10
For some reason my ABS light went on a few years ago & the sensor in the rear end was broke. Got it changed & it solved the ABS light. But I also thought the ABS sensors were at the wheels.
Anyway a 1000 mile trip & no lights or issues. Avg 12.4 mpg @ 72 mph. Not bad for a V10 4x4.
Thanks for the responses.
Merc225hp
NA
truck
gas
Rear speed senor is also the abs sensor. 4wd trucks do not have front abs in these year trucks. 4wd only have rear abs. Fsm is a great place to get info from.
Orca
