ABS Controller Harness pin removal
Fgrjk2013
New England
Hi all
I’m new to the forum with an 05 Ram 1500 slt. I have the dreaded ABS/Brake light illuminated and actually found the culprit. I have an open left side sensor wire (negative). Now I cant remove the pin from the control harness. Can anyone provide some guidance here? I searched the YouTube “general service manual” and have not come up with anything that’s working for me. I was hoping the blue cover came off but I feel like I’m going to break it yanking on it. Photo attached of a similar module.
Daw14
Try the 3rd gen section under audio/ electronics , search around there . Amazon has depining tools and pins .search automotive electric pins
F
Fgrjk2013
New England
Great thanks! I was able to figure out the harness. You have to be assertive and pull the blue clip out with needle nose pliers. From there just insert a thin pin/screw driver and the pin falls right out.
Lowrider357
