AC issues with floor vent
phxramguy
Phoenix
Hello, I have a 2019 classic with a 5.7. I recently replaced my electric fan / blower motor / and blend door. I started the truck and it was only blowing AC out of my floor vents. I went to work and when I drove to lunch everything was fine. 2 days later I start my truck and it’s only blowing out the floor vents. I immediately turn the truck off and wait 10-20 seconds and turn the truck back on and it’s blowing fine. Any suggestions?
jws123
nj
You probably need to re calibrate the blend door acuators since you replaced the blend door I did it with my scanner not sure if there is another way.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
the MOPAR actuators are self calibrating, the actuators are small motors & gears
usually there are 4 fairly accessible actuators
the actuators are mechanically connected to the Blend Door & the Mode 1 & Mode 2 doors, the 4th actuator works the Recirculation door
If everything in the HVAC Box is good
The doors can sometimes work wonky, be glad that they aren't run by A.I.
Try this simple reset ..
when he takes the glove compartment out ...
Notice the duct tape
watch him work the white part, LISTEN to the sound as he moves it back & forth, Do you hear the THUMP ?
That means the door inside the box properly functions
continue watching
IF you have a different HVAC Control setup
leave the hammer on the bench
P
phxramguy
Phoenix
Thank you for the info. I can't seem to find a video of how to reset the hvac with dual climate. All my knobs are different from every video I have seen.
