Runaround
I have an 07 Ram and my ac isn’t cooling at all.
I got a set of gauges from O’Reilly so I could check the pressure. I started the truck, put the ac on max and recirculate, hooked the gauges up, noticing the compressor cycling on and off. I thought they stayed engaged in the recirculate mode, maybe not. My pressure readings are 55 on the low and 450 on the high while the compressor is engaged and the gauge connector for the high pressure side was extremely hot.
i will get readings again tomorrow evening of what they are when the compressor cuts off.
