- Jan 17, 2016
- 14,066
- 24,390
- 14 Sport
- 5.7
Then he might want to look into putting a set of paddle shifters in it,Maybe he can't afford a new thumb?
Plus hitting the - button drops into manual mode at the current gear. So if i put the truck in drive, then hit minus, I also have to hit plus 8 times.
There, are you happy, I explained myself. Now the stars are aligned and you can shut your yap. I don’t want to press the 9 buttons let alone even 1.
Let’s push this baby to 5 pages before someone can answer!!!
Shouldn't be hard to find these "others" as you say,just message them on here,if they're still active members.I have heard it being done successfully from others. I don’t care that you don’t think it can be done, haven’t heard it done, don’t know anyone that did it…
If you don’t have anything constructive to say then don’t say anything at all
Man so many people here with time on their hands. (Well not many, the same few people that know who they are)
Way to band together and help make the community learn new things.
Naw it's your attitude that's made a few of us band togetherMan so many people here with time on their hands. (Well not many, the same few people that know who they are)
Wait, please let’s continue discussing how it’s AlphaODB and not AlfaODB. Maybe we can let the developer know he’s got it wrong.
FWIW, @bountyhunter had it work on a 2017 (or 2018) Eco Diesel from another forum. I know people here said it can’t be done, although I suspect it’s because they didn’t also confirm the setting on the ECU.
Would be nice to learn more about success stories from others to piece together a senario that might also prove to work for the Hemi and other diesels too. That being said I never checked the other diesel ECUs, they may have a setting for “Actual Gear Display”. I just know I saw it on the Eco diesel trucks.
Your first post says you're getting it tuned this week to disable MDS,so you'll have to buy an unlocked PCM and bypass cable to accomplish that,get your tuner to use HP to see if he can activate it for you.He had it enabled by a tuner on his 2016, yes, but not on the one he did for a friend. Go back and learn how to read.
And I quote... "The gear indicator is on in my '16 due to the transmission tune programming. I have successfully turned on the gear indicator in a '17, so it should be possible in your '18"
Although previously he called it a '18 in reference to his friends truck, so I'm assuming it was an '18 and not a '17...
But by all means continue to tell me how I'm wrong.
