Is it the same exact light as the middle dome?
Do you have a PN, link?
I picked it up off ebay cause it looked the same as the one in the middle. Like I said, I still have not pulled the liner in the rear yet to install it, to freaken cold, but should do it soon. its a very small light unit and figured if it was not exact I would figure out a way to install it and use it. The part number on the unit is 5JG55BD1AD
Was the front one hard to do? I just have the light over the back seats, I hate not having map lights up front.
I did the front one, took about 2hrs to do, the hardest part was getting myself to cut up a brand new head liner, but with a real good blade it went very well, I did a starter hole to find my roof clips for the unit, then used those to mark my outline for the unit, with a few adjustments got it installed pretty quick, tapped into the wiring connector on the left side of the dash, the green plug and wired it up, One thing you need to do is make sure you tie and attach well the cable your going to use as if you don't and you hit bumps in the road you will hear the cable hitting the roof liner above your head. I only did the lights and the green LED the lights up the floor, I will be installing my heated seat switches on it this summer.
