You’re the first that I know of to report about adding autotech’s keyless go WITH a memory fob. From other posts, it seems that they are not enabling some of the features that go along with it. This one is different because (I’m assuming) you already had the memory fobs before, so nothing should have changed, but can’t be certain. A few other things I’m not sure if they addressed- if you sit in the truck with your fob inside the truck and the driver door open, then lock the doors with the door switch, when you shut the door, do they automatically unlock? Also, when you open your door to get in the truck, does the instrument cluster display “brake + start button to start vehicle”? These are some of the features that have reportedly not been enabled by them.
You wouldn’t happen to have the alfa software to be able to connect to the driver seat memory module and see if “key fobs linked to memory” was disabled somehow when the new RF Hub was programmed?
