Hi all,
I'm installing aftermarket fog lights in my 08 Ram 1500. I want to connect the power wire from the light switch to the fuse box with a fuse tap. The harness that came with the lights has an in line 15 amp fuse that comes off the relay and will get connected to the battery. My question is, does it matter to which amperage fuse that I connect the switch power wire to?
Thanks
Thanks
