I am curious as to how you tried, As i said i have not done it, I thought i heard that if you took it off base system and turned on the premium system that it would just monitor the pressures like on the 3500s. I am going to play with it this weekend and see what i can come up with.Unfortunately didn't work for me. I'm also just getting started with it. I did base and premium.
The baseline system fob programming hasn’t been working for the last few updates. The last known working version is 2.1.6.4 (Android).Can someone help me program my key fob's? Am I missing something? Do i need a specific headlight on or something else. Here is what I have tried.
Car: 2017 Ram 1500 Express
I have ordered 3 keys from amazon. Its not the "keyless start" kind but the ones you have to put into ignition. The FCC ID was identical in the listing on amazon (GQ4-53T) but once i got the key it showed a different FCC ID (2aokm-cyv2) so maybe that is why it failed. But i assume its just because they should still work for the one in the listing? My remote is the 3 button, unlock - lock - panic. One of the reviewers on the single pack said they got it to work before though i ordered double pack.
https://www.amazon.com/gp/product/B07982G11C (3 button pack)
https://www.amazon.com/gp/product/B0797Y577W (4 button single)
I followed the guide per this thread using alfa and mx obd. I got the pin from the "pin puller" android app since dealer said no. When i put the key to be programmed into the ignition, I left it as it was "off" - nor turning of the key. (Not ACC or ON or engine started). I tried programming using the "baseline system" keyfob (NOT 'highline system', or the default 'Program Ignition Fobik's'). After clicking start i get a message on all three that states:
Failed. Conditions not correct or Request sequence error.The fault afterwards reads as follows:
Faults Found / Error Code:
B1A24
Key Not Programmed
Last test completed unsuccessfully
Error Present
Failure Warning Lamp 'ON': Not Requested
Anything i need to try? Headlights on? Warning Hazard lights? I really want to get this to work.
Thanks for the help!
The Alpine system uses the same radio as the standard 8.4 system. We haven't been able to retrieve the unlock code for the radio with the tool at this time.On a 2013 with the Alpine stereo system can the AlfaOBD program retrieve the radio pin code.
Here is pic of my radioView attachment 160724
That wou
That is the setting I used on my Ram and it worked. I do remember reading on the forum somewhere that if the vehicle is Canadian (in the Alfa settings) that no matter what you set in the drl settings wont do anything. I believe they had to change that to USA to “unlock” the drl settings. Do a search, but I think it is in this Alfa thread somewhere.
I recall reading something like that, too.
I've been combing this amazing thread, for days...
Thanks for the info.
Bob
Thank you! Just tried with that version and it worked. Had to reactivate alfaobd but the dev did so quickly.The baseline system fob programming hasn’t been working for the last few updates. The last known working version is 2.1.6.4 (Android).
I have a Canadian RAM with an R2. To enable the option under lighting I made the following changes :on my 2014 Canadian spec I can turn on/off drop out and it works also can change location of the DRL...
I have a RA2 radio and have NOT had the DRL customer menu option initialize and is over a week now
Seems to be working! I have to be travelling over 22Kph (~14mph) for them to activate.Also remember the headlights need to be in auto setting in order for the auto high beam to function and it needs to be dark outside.
That's great. As far as I know you are the first person to get it to work with the RA2 radio. Is the option to turn it on an off in your settings menu on the radio yet?Seems to be working! I have to be travelling over 22Kph (~14mph) for them to activate.
Need to observe a bit more before I decide I like it. So far it seems to be very sensitive. Reflectors on mailboxes and shiny ice piles seemed to occasionally cause it to dim the lights.
Ok so I adjusted my tpms sensor pressure to 60 and now that it's around there it says I flat to 60 psig but I put 65 in and still no change is there another setting I have to change to get it to really work at 60
Sent from my SM-N950U using Tapatalk
I would think so. I’m not sure if anybody has tried because everyone just uses this method:Can the Seat belt chime be disabled with the AlfaOBD program in a 2013 ram big horn?
thanks
Yes. Keep trying.Well I tried 3 times and did not disable the chime.
Is the directions suppose to work on all rams as mines a 2013.
Any other suggestions
