1zero3forlife
Thanks, that makes me feel a little better right now. I appreciate that greatly.See posts #4156 and 4157 here:
https://www.ramforum.com/threads/alfaobd.123982/page-416
Sent from my NX629J using Tapatalk
They said they only have 15 minutes to retrieve the code once they get the code from FCA in am email and the code was only good for 3 hours. We will find out tomorrow once I get the unlock cable. I will report back. Thanks
Sorry, I sold that truck and got a 2018 2500 Cummins TradesmanYour profile shows you as having a 2017. What unlock cable are you getting tomorrow?
What year/model is your truck (2500) ?Thanks bob.
I guess i need to see if i have power at camera. I purchased the mopar splitter for tailgate latch. The factory harness seams to have the correct wires tk match up with camera splitter. So i think my next step is to use voltmeter and see if i have power for camera.
Then i can trace those wires back tk radio with tone generator. I m afraid the factory harness at tailgate does not connect to radio. Since tailgate appears right and my truck had camera as an option With the 8.4 radio, i was hoping wires where already there.
I can return oem camera and order oem camera kit and pull wire, but was hoping not to.
Can someone provide alfaobd step by step? I might be missing something.
I have to call BS on this also, i was watchign the guy at the desk computer.... he took my vin typed it in, searched around, then BAMM wrote it down. He did ask when I was going to install this, because the code is good for 24hours. Or atleast the older radios were. Thats BS, how many radios online do you see " with security code" advertised... how are they going to get you the radio and code and get you to install it in less than 24 hours... How does a radio when first plugged in, know if its the correct sequence of a rotating code? they dont. its no different than a bios password on your computer. Dealers dont know everything.They said they only have 15 minutes to retrieve the code once they get the code from FCA in am email and the code was only good for 3 hours. We will find out tomorrow once I get the unlock cable. I will report back. Thanks
What year is your truck? The Trailer Hitch camera wasn't an option until 2016. If you have 13 to 15 it will not be in your BCM to enable. If your truck is a 2016 or newer the option should be present.When looking through body computer the only thing i cannot find is
Trailer hitch camera.
Where is it?
So would i need new mirror?
Both cameras show up in uconnect with blue screen i enable them, but something is not connected.
I pulled radio and do not see any rca plugs.
It's not common to have all the wiring and just need the pieces in the tailgate. If your are getting a blue screen in reverse, it's definitely not a programming issue.
See...
** Installing OEM backup cam .. Post 10 as well as the OP **
Post any camera wiring questions in that thread so you don't clutter up this one. There are several people that monitor it.
And this may also help
My 2013+ Shared Schematics and other OEM Info.
M² Mods.
I have 2013 ram 1500 quad cab 4x4
Thanks. I will review all you provided
I had a 2013 1500 SLT previously and the wiring was missing from the tailgate all the way to the radio... Yours is likely missing also.What year is your truck? The Trailer Hitch camera wasn't an option until 2016. If you have 13 to 15 it will not be in your BCM to enable. If your truck is a 2016 or newer the option should be present.
Just am update, you all were right! I have keyless entry now and I am waiting on the hub to reset for 30 minutes to try the remote start. So damn excited this worked.
Thanks, just had it not work, I will take it for a drive here in a bit then. I went through all the settings again just to make sure and all is correct. Thank you for the tip.If the remote start doesn’t work first try take it for a short drive and turn the truck on once or twice.
If you are not 100% sure, you need to check for all 8 wires at the i550 tailgate connector going to 5 wires at the c322 connector (chassis harness), 3 wires at the i315 connector to the 3 wires at the radio C1 connector (cab harness). If you don't know what I'm referring to you will need to refer to post 10 in the bu camera thread that I linked previously for pictures and exact pin numbers to check. It also has a summary schematic for the bu cam. If you're just missing one or both of the main sections I may be able to get you what you need.
13-17 OEM Backup Cam Install i315 mpg2 9-4-17.pdf.
As Ricks Ram mentioned, the 2013-14 BCM doesn't have all the same options as newer trucks (but Cam can be enabled with the ones it has).
M² Mods.
I had the 4 digit yesterday, that is when they said it was rolling.Congrats.....so I imagine you got your 4 digit PIN? Curious...how did that go down at the dealership when you went back? Did you instruct them that they were clueless?
