I just had an odd and somewhat disturbing incident trying to use the new PIN read function and I'm curious if anyone else has seen this.
Notes:
-I've used Alpha to do many things on my truck, many times
-Alpha is the latest Android version running on a Samsung Tablet
-Scanner is an OBDLink MX Bluetooth
-Truck is a '14 1500 CC Express, RF Hub is original, key in use was one of the original OEM FOBIKs.
I already have my PIN from the dealer and have used it before, but I decided to check out the new function just so I could be aware of how it worked and to see if it gave the expected number.
Went in, connected, selected the usual options and went into the RF hub, went to Read Pin. Truck was in "Run" with the engine OFF, as usual for doing anything with Alpha.
I hit Start and the entire truck died. Dash shut down, radio shut down, everything. (I am not certain if the dome lights went out, it was full sunlight and I forgot to look). Alpha popped up an error saying something along the lines of "Unable to read to/from ECU". Cycleing the key had no effect, truck would not turn on much less start. I had to turn the key off, shut the door and wait 5 minutes before it came back to life. (Next step would have been to disconnect/reconnect the battery). It seems fine now, it runs, remote buttons work, no stored codes , etc.
I have NOT tried again and do not intend to do so until I can report this to Alexy.
-K
