Alignment after leveling kit?
Tonyhawk196
Hey guys,
Simple question... Do i need to get an alignment after a 2.5 inch leveling kit install?
99RamSport360
5.9L Magnum 360
It is highly suggested, and the instructions should say that you need to... I did just to be on the safe side... I would if I were you
99RamSport360
5.9L Magnum 360
If you don't have ajustable shocks, you might think about replacing them with adjustable or shocks for lifted trucks... It might be alright though, someone else might know
Texasez
Dallas tx
Mine was way off after the leveling kit. I'd definitely do it. Rides way better after alignment too.
quietpeen
2021 TRX
Hellcat
Yes
partsguy
SHREVEPORT LA
HEMI 5.7
it depends a lot on the kit you use. skyjacker sells a replacement strut that they call a leveling kit. if it is a strut spacer that would be different.
quietpeen
2021 TRX
Hellcat
It doesn' matter what you use to level the front . If it has anything to do with the suspension you are changing the geometry and an alignment is needed. Body lift is the only change that wouldn't require an alignment
Stroked
Beloit, Kansas
Definitely. I only put a 2" leveling kit on my 2012 and it was way out of alignment. You could easily see the tops of the tires leaning out.
Texasez
Dallas tx
Mine was pretty squirrelly over bumps. Not to mention screwing up tires.
Just had my aligned after Bumper install and level kit, the pre alignment report was man it was out of whack! Definitely needed, post alignment report A ok.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Yeah go drive it you wont need to ask the question then..lol
mine is way out of wack.
Lowrider357
