Alignment issues
Tteal235
Hey guys, I've had my truck for a little over a year now and it has always pulled just a little to the right. When I bought it, it was way worse and I had the dealership correct it.
So they changed the upper ball joints and did a re-alignment. But it didn't seem to fix it and I'm starting to see the tread on my front passenger tire suffer for it.
Does anyone have some knowledge on this subject and can point me in the right direction? Suspension isn't really my area of expertise.
usaf2006
Augusta, GA
Mine always has too. Keep those ties rotated. Pulling to the right is pretty common for Rams. If you fall asleep at the wheel, at least you won't go into incoming traffic!
Tteal235
Tteal235
Hahahahahahahaha. Well I guess that is that then
Eestee70
Chicago
Did you get a print out of the alignment specs?
Joe.G
2004 SLT Quad Cab Short Bed
I had mine checked 3 times, No matter what we do it pulls to the right not bad but it does. I am not having a tire wear issue and I just rotate the tires every so often.
Jems007
