All lights on mod
Discussion in 'Tech Info' started by mpress2570, Jan 7, 2017.
  1. BBRAM2500
    BBRAM2500 Senior Member
    38
    203
    62
    Jan 3, 2017
    stony plain Alberta
    Ram Year:
    Engine:
    6.7
    To reply to how to have all lights on all the time the easiest way in my mind is to wire a relay to the low beam as it is on all the time (except when driving lights are on) and power your hid fogs off it. a digital ballast will draw between 35w and 55w so a massive relay is not needed. that is how i would and have done it then get a resistor to plug into the old can bus harness to not get a message
  2. 12sportmc
    12sportmc Senior Member
    33
    803
    342
    Oct 21, 2016
    NC
    Ram Year:
    Engine:
    When I had LEDs in my fogs and HIDs in the projectors there was no issue with bulb out messages or current draw. When I switched the fogs to HIDs all I added was a CANBUS adapter. Again no bulb errors when run alone or with the low beams at the same time.
    mpress2570 likes this.
  3. mpress2570
    mpress2570 Senior Member
    27
    391
    210
    Jan 7, 2017
    Ram Year:
    Engine:
    Don't you need canbus for leds too?
  4. 12sportmc
    33
    803
    342
    Oct 21, 2016
    NC
    Ram Year:
    Engine:
    For the fogs generally no. They will have the resistors built right in. An example of this would be the Diode Dynamic XLM2s. For the high and low beams it depends on the brand used whether the capacitors will be built in or if you will need to run an additional resistor or CANBUS adapter. The 09-14 trucks are generally a lot easier to mess with on the lights because the CANBUS system wasn't as sensitive as the 15+ Rams. For any HID a CANBUS adapter or relay harness is required. Hope this helps
  5. mpress2570
    27
    391
    210
    Jan 7, 2017
    Ram Year:
    Engine:
    Yeah that's some helpful information. So say I just want to get HID what all do I need. For my charger all I have is 35w canbus ballasts. I want 55w for the truck. If I have canbus ballasts do I still need the warning canceler? I'm going to get the relay harness because I don't want to run too much power through my light harnesses and screw something up but here's what I have selected for heads and fogs (note it'll be a 2017)
    [​IMG][​IMG]
    Also what is the best brands to look into. I got my kit for my charger off of these guys and I've had them for over 2years and no bulbs have gone out yet.
  6. 12sportmc
    33
    803
    342
    Oct 21, 2016
    NC
    Ram Year:
    Engine:
    You will need to run the relay harness on the 17 model. It's way more sensitive then my 14. I ran Morimotos on my 12 and now on my 14 and have had zero issues with them. Quality is top notch. Other people are running DDM kits and seem to like them. They are a lot cheaper. I just stuck to what I knew worked on my 12 for my 14. Have you looked into getting your stuff from Retroshop? Here's a link. Better product and excellent customer service. http://shop.retroshop.us/
    Call Jeremy on Monday and he'll get you taken care of.
  7. 12sportmc
    33
    803
    342
    Oct 21, 2016
    NC
    Ram Year:
    Engine:
    Also on your fogs you would want to add projectors to get the most out of the HID. They don't work very well in a stock fog housing The pic I posted is 35w 5k bulbs in the Morimoto matchbox projector
  8. mpress2570
    27
    391
    210
    Jan 7, 2017
    Ram Year:
    Engine:
    I looked into the morimoto system and I like what I'm seeing but now I'm confused by the purchase options. There are so many bulb sizes for the 2015+. I'm pretty sure I will need both 9005 for lows and fogs. I'm not sure though. But the truck I'm getting does have the factory projectors.
    Also I don't see any options for canbus or capacitors just the mopar harness. This site has confused me haha. Sorry to keep bothering you I'm just trying to figure this all out so I know exactly what I need to buy. [​IMG]
  9. OnSale
    OnSale Senior Member
    31
    1,661
    462
    Nov 12, 2016
    Philadelphia, Pa
    Ram Year:
    Engine:
    LED Bulbs usually come with the following:
    ▪Bulbs:
    [​IMG]
    ▪Drivers:
    [​IMG]
    ▪Capacitors:
    [​IMG]
    Look at it like this. If you compare an LED Kit to an HID Kit, the LED Drivers are pretty much the "ballasts" if you want to call them that. The Capacitors are pretty much the "error free Canbus adapters".
    Everything is smaller and easier with the LED Kit. The HID Kit is more complex and "harder" to install if your a novice.
    It really just comes down to preference. I had the Opt-7 Boltzen Bi-Xenon 35w 6000K CanBUS HID Kit Relay Capacitor Bundle on my 2006 Ram 1500. The kit was a nightmare to install, wires had to be cut and switched on the relay plug that connected to the trucks H13 plug. It was horrible. Then half the time the lights wouldn't turn on, I'd have to flip the headlight switch off and back on again. They took a long time to warm up and the lighting actually sucked big time.
    Now I have the Opt-7 FluxBeam-X 6000K H11 LED Kit in my 2012 Ram 1500 and the output is amazing. They are 10x brighter than the 6K HID bulbs I had in my 06. There is no delay in brightness when you first turn them on, I dont have any "dead spots" or "black areas" in the light beam pattern that some people get with hid's and led's.
    In the end, in my personal opinion, the LED kit was 1,000x easier to install. It only took about 25 minutes from loosening the first bolt to tightening the last bolt. All I had to do was remove the old bulb, connect wires labeled #1 to #1, 2 to 2 and 3 to 3. Then I tucked it all into the housing and closed it up. But with the HID kit it took over 3 hours to figure it all out, run the wires, install it all. I had to drill holes to mount the ballasts, cut and extend wires, cut and switch wires etc. Alot of trial and error. The LED Kit wins, hands down, when it comes to ease and time of installation.
    As for light output, again, in my personal opinion, the LED kit was 10x brighter then the HID kit. The light from the LED bulbs isn't scattered all over. It's more centered and crisp. You can see a clean & clear cut off line with the LED bulbs in a halogen housing that you wouldn't see with HID's unless you have projectors.
    Either way, both are a better option over stock Halogen bulbs. Like I said multiple times, it all comes down to personal preference. Do you want to spend the time hooking up the HID kit or do you want an easy install with the LED kit? Either way you end up with 6000k bulbs that are better then the horrible stock halogens.
    Sent from hell via TapATalk
  10. 12sportmc
    33
    803
    342
    Oct 21, 2016
    NC
    Ram Year:
    Engine:
    No bother man. That's what the forum is for. It will be easier for you to select all your options here: https://shop.retroshop.us/ProductDetails.asp?ProductCode=4G.15.HIDs
    Then you can either purchase from Jeremy or go back to the morimoto site.
Share This Page
