Alpine center speaker
ctdodge
Bristol, CT
2017 Laramie 1500
I have a '17 Laramie with the Alpine system. I have swapped out my sub, rear door speakers and the left and right dash speakers (JBL Club 3020's). Will it make a noticeable difference if I replace the center dash speaker?
Thanks
PowrRam
Minneapolis
2018 Big Horn
3.6L V6
My 2015 Big Horn had the Alpine system. I replaced the corner dash speakers and left the stock center dash speaker intact. After a while, I disconnected the center dash speaker and listened for a week. Then reconnected it and listened for a while. I ended up disconnecting it permanently as I felt the stereo imaging was better with the center dash speaker disconnected. So maybe try disconnecting it for a while and see what you think. It's easy to do. (I should mention I do not listen to the Alpine system in Surround mode.)
All that being said, if you are going to keep the center dash speaker connected it would sound better with an aftermarket speaker. The problem is you can't buy just one, single speaker, gotta buy them in pairs.
