Alright guys.. BILSTEINS post your pics!!!
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
those came off the stock shocks. You don't re-use them
Outdoors76
Rhode Island
Oh I thought you do reuse...
Thanks!
I'm real happy with the ride height
Doesn't drive like a car anymore lmao
Noticeable softer ride.
I think if I do 35's then a 1.5" body lift is in order. Otherwise I like it like it is.
Thanks for all your input guys I appreciate it.
Dave
Roadhouse71
Kentucky
5.9L
Big Dirty is big Probably 10-12" above stock height. Made this lift about Year 2000. Wasn't a kit i made most of it.
snobnk
hemi
Does anyone have the Bils st to 1.4 ??
yortnodnarb
Adrian,MI
I really like the look and reviews on those tires, but why are they so much heavier than comparable tread patterns? They're a good 7-10lbs heavier per tire than most the others, heck they're darn near as heavy as a mud tire.
Gordinho80
Monroe, NJ
2012 1500 Big Horn
So I'm looking to level with Bilsteins. I do not plan on using a spacer in the rear, but I do plan on running the Timber Grove airbags in the next few months to assist when towing my travel trailer. Should I set up the Bils at 2.1 or max them out? Maxed out I'd see the front a little higher than the rear, right?
Gordinho80
Monroe, NJ
2012 1500 Big Horn
So without the bags, and with stock wheels/tires... how would it look? lol
Gordinho80
Monroe, NJ
2012 1500 Big Horn
Thank you. I’ll probably run them at 2.1. Wont have the bags for a while and won’t be towing all the time... so even when I do have the bags, I’ll probably run them at minimum psi, whatever that is.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I started at 7psi and kept adding air untill it started to ride bad.. lol
With my shell I can run alittle more than without it.
Ftank
