ameldorf 19 Ram Classic Express
ameldorf
ameldorf
Lenoir, NC
Couple projects came in:
Ready for first oil change (Redline 5w-30 not in pic)
Diff cover
ameldorf
ameldorf
Lenoir, NC
Diff cover on
Fun tidbit: Freedom Offroad upper rear control arms won’t fit with the IHC relocation brackets. The bushing diameter is too large to fit in the axle side area. 14c93f4370be42a4506cca52eb389731.jpg
ameldorf
ameldorf
Lenoir, NC
Only missing a black headliner now
Also found this “u” shaped part on the frame smacks the top of a larger than stock differential cover.
Not anymore as you can see.
ameldorf
ameldorf
Lenoir, NC
Added Bushwacker Trail Armor rocker guards. They don’t make regular cab specific but the fronts fit for crew cabs. I cut a rear up to cover the cab corner but it looked weird so I took it off.
Should add protection either way.
ameldorf
ameldorf
Lenoir, NC
Airaid Jr intake tube
Had a K&N drop in filter prior, but the Airaid that came with the kit was dry and had way deeper pleats, so I put it in.
ameldorf
ameldorf
Lenoir, NC
First oil change and added remote filter kit
Also added Hellwig rear swaybar
Had to remove the Freedom Offroad panhard due to clearance with diff cover. Gonna try a Spohn non-adjustable.
ameldorf
ameldorf
Lenoir, NC
Bit the bullet and ordered a supercharger. Went with Edelbrock/Eaton TVS 2300 kit
Also ordered a Walbro 450 and new fuel pump assembly. Gonna see if I can figure that out. I’ve modded and fit dual pumps on other platforms so should be ok. Should be way overkill for anything I’m gonna do on stock block.
Finally AEM afr gauge and column pod to monitor.
After all that, some tune time at the shop I take stuff.
tipnitty
Oklahoma
Making some great progress! Excited to see the supercharger install! I should have done a filter relocation long ago. look way more convenient in the new location.
ameldorf
ameldorf
Lenoir, NC
Thanks!
Forgot... I ordered a one piece driveshaft and Core rear control arms to finish suspension.
ameldorf
ameldorf
Lenoir, NC
Installed gauge pod and AEM wideband gauge. Pulled sensor wiring through firewall and routed the power/ground. Not connected yet.
Kinda lame the pod isn’t a replacement piece but a cover. Fits well enough I guess.
ameldorf
ameldorf
Lenoir, NC
Finished the wideband install
Driveshaft Pro ds installed
Core 4x4 non adjustable rear, lower control arms installed. The uppers again won’t fit on the axle side with IHC no cuts. Smaller diameter than Freedom Offroad bushing housing but still no luck. I have a hunch they’d fit with the cuts. May look into it one day.
Still waiting on supercharger to ship.
Gamedog
State #38
2019 PW
392 c.i.
Nice!
You don't mess around, awesome man.
Tuend and ready to go? Or still need to tune?
cam101
NC
That going to be a fun ride indeed. Who is your tuner?
Sent from my SM-G965U using Tapatalk
ameldorf
ameldorf
Lenoir, NC
I’ve used Brutal Speed and Tuning in Maiden, NC for a couple of previous cars. Great shop and local to me. He’s a month or more out so I’ve been working with Hemifever via email since truck runs like doo doo without tune. Great service as well.
Lowrider357
