Amp smoking.
tommyboi87
houma louisiana
5.2 Magnum
Ok so I'm usually spot on with audio stuff but I've run into. Problem that just started today. So my channel port on my amp where the speaker wires hook in, started smoking. I have no idea whatsoever can be the cause of this. I've gone over all my connections, and nothing is loose or touching anything it shouldn't be, but I'm at a loss with this.
Was not set from an iPhone.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
Well thanks to everyone's input, (sarcasm) I fixed the problem temporarily. Somehow the socket came loose in my speaker input on the positive side and burned it up. So what I ended up doing was soldering a screw where the connection was and taping the wires to the screw. Problem solved.
