another speedo problem
foto740
1996 ram 1500 4x4
the entire instrument cluster works except for the speedometer/odometer
(don't know if this helps but)
the other things that don't work are the horn and the cruise and the aux. port (cigarette lighter works fine) and hazzard lights
I have tested all my wires going to the sensors and they are fine.
I have replaced all the sensors and the cluster.
I have checked the voltage to the vss...... (5 volts on both sides of the ground)
I have even ran a wire (white/orange stripe) straight from the vss to the speedometer.... and still have nothing
PLEASE PLEASE PLEASE!!!! HELP.... BEFORE I GO INSANE....lol (to late i think)
dhay13
speedo problem???:naughty: they just look uncomfortable:roflsquared:
F
foto740
I changed out the cluster and same thing....and lol @speedo
MagSport
South Carolina
You could straight wire the speedometer to a gps sending unit lol. This one is weird I don't know what to tell you unless it's a short somewhere. Even then it should've been revealed when you straight wired the vss. Have you looked at the gear in the transfer case yet? Maybe it's missing some teeth.
F
foto740
UPDATE: just had to turn the gear housing over ....now it works just fine....thank you all for your help now time to put a 6" lift on it
MagSport
South Carolina
:Stupid me: glad you got it man crazy how something like that could mess you up so bad.
F
foto740
Stupid me also......i bought the truck with the speedo not working and even checked the gear and didnt even think to check if it was in right....
