anti freeze smell
Reaper26
hey guys new here, i have a 04 ram 5.7 and in the past few months ive replaced the water pump, a few weeks ago the top hose thermostat and housing gasket, but for a while now after it warms up i can smell antifreeze burning, as far as i can tell its not leaking anywhere, and the level is about the same. its not smoking, i cant smell it coming from the exhaust, i have a bullydog gt and the temp stays about 204, i changed the plugs the other day and its obviously been getting hot the wire on the plugs got hot enough to bend back and the gap opened up to about 75 on all of them. i dont know if that has anything to do with it or if its from the tunner, any ideas where i should start looking?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Thisd might sound stupid, but have you checked to make sure the radiator cap is making a tight seal? Also, if you dont live in an extremely cold climate, I would look into a 180* thermostat. These motors run much better when cool, so I would look into replacing the stock thermostat reguardless of what is causing the coolant smell that you have now.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Check the overflow tank to see if its weeping from the seam or top also. My truck weeps at the top when we do sand drag racing. Its not really loosing but a fraction of an amount but you can smell it.
Reaper26
Reaper26
i changed the radiator cap as well, an as far as the thermostat when i changed it it was the same, i didnt go colder with it. and ive looked around the seem on the tank and radiator but dont see anything leaking.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Im referring to it not even leaking that much just a damp spot that is weeping just bearly. Fluid will also slosh up into the overflow drain some and you can smell that.
