Anyone tried the Zone 3.5"
lokal907ryder
wasilla, AK
this is mine with the zone UCA's, bilstiens up front set @ 2.1" and the zone 1.5" body lift. looks no where near as big as the one in their picture. leads me to belive that's a 6" lift.
HemiPower36
HemiPower36
CA
2014 Ram 1500 Laramie 4x4 3.92 8-speed
the zone upper control arms provide no lift. they are just a stronger solution to the rams that had the ball joint issue. I saw now lift from mine. you can add the zone 1.5" body lift with the bilsitein 5100 front leveling struts but you can not add the strut spacer on top. sounds like what would work best for you is the 5100's up front and the zone 1.5" body lift. add the UCA's if you think your truck might have ball joint issues. I got mine just to be safe.
Can you explain this kit then. It is the zone 3.5 without the 1.5 body lift.
lokal907ryder
wasilla, AK
that is a 2" lift. those pieces above the control arms are strut spacers that achieve the 2" lift. the combo 3.5" kit is the same just the addition of the 1.5" body lift. the upper control arms are just a replacement for the stock ones that were having the ball joints popping out ( common on the 13+ 1500's, lots of fourms regarding this issue)
HemiPower36
HemiPower36
CA
^ alright. It all makes sense now. Thank you very much. I like your setup, and I think I will do that.
lokal907ryder
wasilla, AK
no problem! I think you will be happy with the set up. soon im going to set the front struts @2.8 and add a 1" rear spacer. that should look really good.
JustinRam1500
