Ash Tray removal
Dean2
Near Edmonton
That "cubby" you speak of was that on another thread. Is that the "useless " hole' to the right of the radio? That might be a place to put a switch ..seems to me someone addressed that very thing..I will search..thanks Dean2
No what I call the cubby is the drawer that is open in the picture you posted.
hemihustlin
Montreal
doesnt help the op but:
I dont know if anyone takes it but there was a close to 100$ CAD smokers convenience package when I was building trucks on the mopar website last spring. I thought that was cool to see in 2021 haha
Dave Haddon
Dave Haddon
Saskatoon SK. Canada
Sbannon had the idea of OTRATTW rocker switches in that cubby..going with that rather than the pull out tray..just need some insight of how to get wires up in there. I can drill a hole like he says but a guy will be feeding blind trying to get wires to the switches..any ideas guys?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Dave, take off the radio bezel
up on the top of the dash above the radio
there is a cubby with a rubber tray, remove those 2 screws
Do you have a 110 outlet on the right by the temp controls ?
If not you can grab, the cubby that you removed those 2 screws from & give a semi hard jerk to release the first of several clips around the edges of that bezel.
The radio will not move even a fraction of an inch
watch this short video, if you are unsure about it
Now that that is done, the tray has 4 to 6 screws holding the whole tray unit in place
GTyankee
3.0 ecodiesel
Also behind that bezel, about where the temp controls are,
there is a power source that you can work with
Dave Haddon
Dave Haddon
You guys are awesome...a real bummer they never had automotive shop when i was a teen...I just love getting into stuff..but scared to do something stupid and break my new truck..thanks again guys.
averageguy
Belleville Mi
hemi
I mounted the controller for my pedal commander in there. It took alot more effort than it should have. 2 minutes after I was done they started offering a pedal commander with blue tooth.
Dave Haddon
Dave Haddon
GTYankee..wow that seems like a ton of messing to get that tray/storage tray out doesn't it..may have to go for a different option..thanks for the info.
Dave Haddon
Dave Haddon
GTYankee..video was a great help..to the right of the radio dials there is that little cubby where i have 2 switches. The lower portion looks solid. Would you know if that is a place i can cut in or remove. I cannot feel behindIMG_0228.jpg
GTyankee
3.0 ecodiesel
Again, there is a pocket above the radio screen
there are 2 screws under a rubber pad in that pocket
remove those screws
next grab that pocket with the fingers of both hands are give a healthy jerk, it will be noisy & you may believe that your going to break something, your just popping some darn good clips loose
there are dozens of videos showing how to do it
put some tape over the tip of a straight slot screwdriver to pry with, so that you don't scratch the plastic, if you don't have a plastic pry tool
Once those clips are released, the are only electrical connectors on the backside of the radio bezel
Found a video that explains it much better than words
Dave Haddon
Dave Haddon
Yep did all that with success. However I am asking about that cubby to the right where just above it I put 2 switches. Is that a solid plate. I tried a plastic pry tool did not budge. Anyone know if that little cover comes off? What is behind it?
GTyankee
3.0 ecodiesel
Once you unplug those electrical connectors on the backside of the radio bezel.
You can put it on a bench & break out electric screwdrivers & a Dremel Tool.
I THINK, that there is likely a plastic box, either riveted or screwed onto the backside of the radio bezel.
I have not pulled off the bezel on anything newer than my 2016 Ram
