Every 09-up Hemi ram has both a clutch fan that is mounted to the water pump pulley, and an electric AC condenser fan that is mounted to the back of the radiator. On the 09-13 trucks, we simply take the V6 model fan, and it takes the place of the stock Hemi AC condenser fan. On the 2014-up trucks, the stock AC condenser fan is strong enough to keep the motor cool, so you simply need to remove the clutch fan that is mounted on the water pump pulley. You are not able to remove the fan shroud like the 09-13 trucks that run the V^ fan though because there is nowhere to secure the upper radiator hose unless yo ubuild your own bracket. The v6 fan used on the 09-13 trucks comes with a mount for the radiator hose, so you are able to eliminate the large stock fan shroud.
As for a belt for the ATI 15% underdrive pulley, you just need to go to any local parts store, and tell them you want a 71.5" 6 rub belt for the 2013+ trucks or a 77.5" 6 rib belt for the 09-12 trucks. The 2013+ use a shorter belt because those trucks also have electric power steering where the 09-12 do not. Every belt manufacturer has different part #s for their belts, but they generally go something like this (715K6)...this would stand for 71.5" 6 Rib. Anyone working the parts counter will know this and should not have any trouble finding the correct belt for you as long as you give them the length and rib count.
