Keep us posted
Sent from my LG G4 on Tapatalk.
Wow , so tell me Sir How do you like your Custom Tronix?
I'm assuming that's what you have .
Have you had any problems with it & how is customer service ?
Have you had to update the software , if so do you do it via the USB port?
And finally did you upgrade to your 8.4" radio or was it factory ?
Thanks for any response .
Thank you Sir !The video on the RAX requires additional equipment. You could use a mirror be, Apple TV, DVD player etc. The RAX provided adapter harness has one audio in and two video in. In order to use the video you need an ab switch hooked into the cargo cam line in so you could hook up a third device. To use it you would turn on the cargo cam and switch the ab to you video source. All video control would be done through the video source. Or if you are not installing cargo cam just hook up without an switch. Very hokey, the lock pick has the same ability but it has built in mirror cast ability making it pnp, though quirky.
