Redfisher1974
- Joined
- Jun 13, 2023
- Posts
- 347
- Reaction score
- 417
- Location
- Palmerston Ontario Canada
- Ram Year
- 2017
- Engine
- 3.6
Sure do! Remember that tornado thingie that you put in TB?Ok. I've seen them too. They used to have 'rings' or discs that went on behind wheels too, remember those? When I was a lot younger I tried some 'miracle' products and later wondered what I was thinking .... . We all probably do at one point in time or another. Remember the 4-prong spark plugs that were supposed to change the world?
I know custom offsets used to use the beads if you wanted them. I thought about it when I purchased my wheels and tires from them, but decided on regular balancing. I think they said at slow speeds the beads don't really work, only at faster speeds is where they work.I guess that I am the only one around that has them. The last time I had tires mounted up the place didn't want to use a balancer on the 265/70R18's so they pushed the idea of the balance beads. So I went along with it. For the most part the beads seem to work, some days they seem to be off just a bit for a few (or once in a while several) miles then it does smooth out and ride good. At times I'll feel a small vibration in the truck the next day none.
It is nice not haveing balance weights glued on the rims.
They still have them, Centramatics, On-Board Wheel Balancers, Balance Masters. I have used Centramatics for years on my 1-ton trucks. Currently have them on my 2020 Ram 3500 HO.Ok. I've seen them too. They used to have 'rings' or discs that went on behind wheels too, remember those?
And it worked. It gave me 3 mpg more on my 68 Cutlass 350/Power glideYep. In the late 70's there was water injection too..
