Battery Changes
Eduardo521
Pasadena, Texas
6.7L Diesel
Good evening all!
I have a 2014 Ram 2500 and in the last couple of days, it has been doing some strange things. When I remotely unlock the doors, the lights flash like normal, but then it immediately locks the doors and the lights flash like I locked them. I had not made any changes in the settings only that when it locks and unlicks, I disabled the horn. Today it did the same thing, but now the turn signal indicators flash a couple of times. Does this mean my batteries are going dead? I couldn't find anything in the owner's manual. I'll research it more tonight, but I thought I'd ask to see if any of you have experienced this. Thanks.
tron67j
Maryland
Not sure what you are saying about changes because first you say you didn't make any then mention turning off horn beep.. Did you make changes using AlphaOBD? If so, hopefully you copied all your settings first and can look at your saved information against your current settings.
I recommend returning to factory original and see if that clears issues. That is cheapest and best way to start diagnostics. Let us know what you find.
If that doesn't fix it you could have bad main battery, bad battery in remote, bad remote, loose wire, or something else.
kdoublep
USA
Sounds like he disabled the horn through the truck options, not Alfa. I think it's coincidence and the truck battery is going bad. Test your battery first.
Eduardo521
Eduardo521
Pasadena, Texas
6.7L Diesel
I changed the batteries in both my remotes. Someone suggested I disconnect the truck batteries to remedy. I will do this today and if it does not work, I'll have both the truck batteries checked Thanks..
RamDiver
Marlborough, Ontario, Canada
How old are the batteries in the truck? AFAIK, in a warm climate like Texas, 2 or 3 years is quite typical for life expectancy.
Load testing the truck batteries will confirm the functional state and identify if they should be replaced.
Many auto parts stores will load test at no cost.
Jeepwalker
WI
2012 Reg Cab, 4x4
Probably the battery, or a module.
I would also look at the battery->body and Batt->engine grounds. Wiggle the TIPM wiring maybe...
madtrucker2016
New York
I would check your truck battery with a load tester type, auto zone does it for free.
