BATTERY.....New and Old thread
RAMaway
Chesapeake, VA.
Hemi 5.7 etorq
Took my dead Costco, interstate battery back after 12 mo. I got the larger 900 cca, AGM
battery. In Jan. I replaced the 2 yr. old battery that came in the RAM, Hemi with E-torq.
with the New 850 cca from Costco. The old thread below:
My 2020 Ram 1500 Laramie with E-torq, at 17 K miles must have a
parasitic draw. Had a fail to start this morning battery down to 11.70 volts.
I charged it up and runs good with check engine lite on, as I suspect it
should be on. Doe's anyone have any input??
My son a Master Mech. checked the draw, and it came down in 2 stages.
The final draw came at about 45/50 minutes. He said that was the longest
he had ever saw. But did come within specks.
Checked my new after 2 wks. and it was 12.35 volts this morning, started and
came up to 14.43 and maintain when I turned on heated seats and wheel, lights
and heater fan.
My Grandson, works on Range Rovers, said with all the drain on RAM battery, and
short trips with heated seats, steering wheel and electric motor for steering.
Going on a 10/15 min trip ever day, the battery is not being replenished.
And he tell his RR customers with auto start, to start the vehicle 15/20 min. before
they try to leave home to further charge the battery, if they do a lot of short trips.
I am looking for ANY input, someone else has to be having this problem.
I have checked and ALL I have is an analog, No digital to monitor as I drive.
RAMaway,
tron67j
Maryland
First thing, telling people to idle a vehicle for 15 or more minutes is kind of nutty, it wastes fuel and idle charge is lower versus higher rpms. The vehicles should be designed with alternator and batteries to not have a problem with short usage since the automotive industry understands the average use of a vehicle is short trips. So the solution is find the problem, not excessively idle vehicles. Each vehicle is unique, maybe the owner has added accessories that were not included in the engineering; maybe there is a software update needed; maybe a bad component is causing draws for extended periods of non-use.
For your situation, after checking the alternator output and battery capacity, next thing is taking a volt meter and tracing as much as possible to see if a draw can found. If not, next thing is pulling all fuses each night and then return one at a time each subsequent night until the same starting trouble appears.
This is the problem with incorporating a sound system, video system, gaming system, navigation system, gizmos to replace simple switches, decorative lighting, and the plethora of electronic options that create both comfort when they work and new ways to drive an owner nuts when they don't. So just like a house when plumbing or electrical problems arise, you don't generally expect the same person to fix both: so expecting a mechanic to be the master of all is really not fair. No offense to mechanics, just the opposite. I think you need to specialize today for a repair center to be able to service all that vehicles have become.
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
Maintenance free batteries are difficult to measure for individual cell strength.
A battery can have a (semi) weak cell from the factory and still pass testing.
I try to remember an annual maintenance routine of cleaning the battery it’s posts / clamps and place it on a smart charger to top it off.
I believe the E torq does have some issues with charging and I think the larger battery you traded up to is a step in the right direction.
I agree with tron67j examining the charging system with the size and output voltage of the alternator.
R
RAMaway
Chesapeake, VA.
Hemi 5.7 etorq
Yesterday my 2020 Ram died 6/8 times, once in the middle of the intersection.
I can ONLY find the simulated analog meter to display on dash, no digital output
of the alternator. After it restarted the meter would sort of jump around till it got
to the center of the meter where it usually rests.
When I got home it measured 12.3 volts. At which time I put it on the charger.
And a couple hrs. later, all was well when I took it around the block.
The original SMALL battery lasted almost 2 yrs. the Interstate replacement lasted
less than 1 yr. And with the short trips I make around town the larger 900 CCA ran
down in 5 wks.
I got to take it in and have it checked out, but I believe it is all the short trips not
letting the battery fully charge. Also ALL the DC motors like the ones on the Air foil
behind the front valance, DC motor for power steering, two motors on the frame rails.
Then the heated seats and steering wheel. I do NOT use the stop/start feature.
I have to have it checked out just in case the E-torq has messed the bed!
That's my story! Anyone else with same/simulacra experience.....RAMaway
Administrator
down in 5 wks.
If your puking batteries that fast, there's a problem with the charging system, it might be caused by the IBS which is on the negative battery terminal which sends information to the ECM to control the battery charging.
gofishn
Iowa
hemi 5.7L, 345 cu in
You do NOT have a Battery Issue and your short trips are NOT the problem.
You got a Electrical Gremlin draining those batteries.
Got to find out, exactly what Gremlin is causing the issues and get it fixed.
Your Master Tech Son should be telling you this already.
R
RAMaway
Chesapeake, VA.
Hemi 5.7 etorq
gofishn, my son checked the drain at the end of the dead (new) interstate battery.
After the truck was shut off we checked the drain/draw with a meter between the
battery cables. Can't remember the Milliamp draw but it came down in two stages,
and it was like 45 or 50 minutes till it was at acceptable level. My son said that was
the longest one he had ever measured.
He tried to check and see if the computer has to be made aware that a NEW Battery
has been installed. Like maybe the IBS system that crash68 mentioned. Could NOT
confirm one way or the other.
My Grandson was in from the west coast where he a Mater tech for Range Rover.
He said that some of the RR that are loaded with all the bells and whistles with
extra draw on the batters and used for short trips they will recommend to start
the vehicle 15/20 minutes before leaving.
As bad as I hate to, I guess I will take it in. Just to make sure that the E-torq has
not messed the bed. As my 3 yr. warranty is up the 17 of this mo.
Thanks for the input..........RAMaway
Dodge 1500 4X4
Rochester, NY
Sounds like your 48volt battery may be your problem for the eTorque system, they've had numerous problems with them, sounds like dealer time.
tron67j
Maryland
If I paid big bucks for a Range Rover and was told the fix for an electrical problem was to idle it for 170 hours a year, I would be gobsmacked.
Any Brand that would have it's technicians tell it's customers to do that instead of finding the real problem and solving it has a poorly designed product and no interest in corporate longevity.
Definitely get the truck to a dealer before warranty ends to at least get the issue documented. I suggest doing video to prove the issue and document a step by step process for the dealer to perform so that they can replicate the issue.
Timsdually
Jersey
Cummins
Try disconnecting your alarm system. I would imagine that puts a constant drain on the battery. Or as was suggested, put a maintainer on it. I own a Mercedes and it has two batteries; one is for starting and one is for the electronics. If not driving much, it is recommended to use a maintainer. That battery just died on me this week. I replaced it with an Optima Yellow Top. They are supposed to be good for deep cycling and dealing with all the extra demands. We'll see.
oe542bob
Hemi eTorque 5.7
Probably the cost, but why doesn’t the manufacturers just install deep cycle batteries? Or when it’s time to replace a battery, just go that way. Not a battery expert, but just thinking out loud.
R
RAMaway
Chesapeake, VA.
Hemi 5.7 etorq
Just got the RAM back from the dealer today, just as I thought it came back with a clean
bill of health. The parasitic draw which my son had checked a yr. ago was the same that
we had found. Came down to 30 milamps, but took 40/50 minutes when we checked it.
I was surprised that the draw was 10 AMPS, for the first 10 minutes, and it came down in
two stages for us.
So I will either have to drive FARTHER, or put a battery tender on the 900 CCA interstate.
Thanks everyone for the input..........RAMaway
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I suggest that you really consider buying a MOPAR Extended Warranty at any day before the Original Factory Warranty expires.
There are several MOPAR Extended warranties that are sold be Discount dealers, such as
Ziegler Mopar Extended Warranty
I think they are 20 to 30 % cheaper than your own dealership
Personally, i believe that every time that you Start your vehicle, that you have to drive 7 miles, just to replace the juice that was used to start it.
So if you start your vehicle & drive to the 7/11 that is just down the road & then drive to the Home Depot, then drive back home, you have to drive at least 21 miles to restore the charge in the battery
gofishn
Iowa
two stages for us.
Did the Dealership state this parasitic draw is Normal?
Curious.
R
RAMaway
Chesapeake, VA.
Hemi 5.7 etorq
GTYANK, lets say your assumption is right about the 7 mile figure. Now I turn on the
heated steering and seat, back out of the drive with the electric steering, start with the
start/stop feature engaged get up to speed the front airdam and shutters deployed along
with the two frame activated motors (ever what they do) Heater fan and radio are on.
NOW how far have to drive to brake even?
Dealer did NOT say that 30 mils was good, but said THE system is within spec.
I can't remember for sure but when my son checked it a yr. ago, as I remember
the draw was over 100 plus milamps for like 45/50 minutes.
Son stated at the time, he had never seen one that took that long.
I have the system on a charger as we speak............THANKS EVERYONE for input.
RAMaway
tron67j
Maryland
The presenter highlights some of those things that can lead to problems. And the axiom is: The more things you have, the more things there are to go wrong. Such as his discussion about the door handle on certain trims and how touching it can wake things up. All it takes is a faulty sensor to create havoc and it is possible that humidity, temperature, wind blowing things, or a host of other possibilities are creating false positives for the sensor.
This all just means that we expect our expensive purchases to work flawlessly all the time, but that expectation is not grounded in the reality we live in. Some options are spending lots of time and maybe money tracking down the issue, buying a battery tender, or getting less technology in a vehicle.
runamuck
dfw
6.7 dsl
I have never hooked a tender to any of my cars/trucks but have one on both my motorcycles. am thinking I might want to put one on my '19 laramie.
Atcer2018
Virginia
“Could not duplicate” is a common response from a dealership especially with warranty claims. Your dealer stated everything was within specification but that doesn’t mean something isn’t wrong. There are thousands of Ram trucks loaded with electrical equipment/options including EPS, heated seats, active grill shutters, power seats, fancy radios, etc that do not eat batteries. My 2018 which has EPS, AGS, 8.4 Uconnect, climate control, heated wheel and seats plus an aftermarket Kicker Key amp had the original battery for over four years. As Tron67j stated earlier vehicles sometimes need specialists these days and you may be better served by taking your truck to an automotive electrical shop and paying them to find the issue.
