Best Brake booster
RustyRamFan
Knox Indiana
1991 W150
318 auto tranny
Truck moans at me when I press the brakes, even when already stopped. This means brake booster yeah? I only had this one for 4 months! Whats the best place to source new brake boosters that will last a while?
1970Pelle
90 W150,ShortBed/87 Ramcharger 2WD project
W150 318,4bbl,auto4x4 VGC/ 87 Ramcharger 318/904 VGC
I doubt your moan is coming from the booster. Most times the noise is from the disc pads moaning at a stop. And the truck is moving ever so slightly at a stop, and the pads are rubbing against the rotor causing the moan.
If you want a better power brake set up. Swap from Vacuum boost power brakes to Hydroboost. Which are powered from the power steering pump. Do a Google search and some reading. Its an easy conversion, I have done all the Jeep CJ's I have owned.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
moaning when already stopped rules out contaminated drum brake shoes.
is it possible to have someone press the brakes while you listen under the hood to figure out where the noise is coming from?
a bad booster would likely give you a stiff pedal feel and weak stopping power. the stock brakes are pretty decent in these trucks for unladen power.
threewheeler80
318ci
Apply a little pressure to the brake pedal while starting the engine, as it starts you will feel the pedal drop a 1/2 inch or so or less.
PaPitt
Stephenville TEXAS 76401
5.9L
3WHEELER 80.
NOW What does the drop tell me . Sorry I've not understood where your going with this problem . Are you saying that's a bad booster .
.....I'm trying to learn something here .
BadHemi2014
Greater Cincinnati area
The pedal drop indicates a properly working booster.
Here's a link to a write up of how to check a vacuum booster. It also explains the hydroboost system.
Might at least get you started.
Test brake booster
Orca
