best level for newer 2500
old_hat
Cummins 6.7
How's the axle? still centered or do you need a adj. track bar?
Sorry man, just saw this. No trac bar needed. Only a wheel alignment. Centered fine. I've read on forums if you go 2.5", you may need new trac bar.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Your front axle will not longer be centered in the truck; that's what VTBighorn is referring to. Yes they will be able to center the steering wheel when doing the alignment but that's a different question.
With the 2" level your front differential will be shifted to the driver's side of the truck no question.
