Best Mods for Under $100
Purplert
How’s the quality of the bakbox? I’ve been considering one to throw some of work tools, hard hat etc in there.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
It is easily "gougable" so if in use, and you have gear sloshing around, a slam on the brakes may ding it. It's cool how it folds up and gives me total cargo space. Like I mention above, the adhesive on the velcro is bad, so securing it for use needs to be rigged, but it's doable. All in all, worth the $ and the convenience. But that focker is no $100 mod!
McBroom
Denison Tx
Hemi 6.4L
Where u put washer under the mounting bolts of the seat frame. When raised up it makes it able to clear the rear hangers so top seat can fold down when u lift bottom seat up.
Pictures please
Immortaldaul
San antonio tx
5.9 magnum
Just added these (got 4) a few days ago flush mount stainless bull ring anchors: https://www.amazon.com/gp/product/B00PGH959E/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 They look great and at only $15/ea I don't see why every RAM owner wouldn't have them unless you have a camper shell or rack blocking your stake pockets. I used a box cutter to cut out the scribed areas of the bed rail which worked fine don't need to use a router like they suggest.
I have this on my truck but black I've used em twice but they look good
Sent from my Moto G (4) using Tapatalk
Odin
Arizona aka HELL
Hemi 6.4L
Here are the factory LEDs with red Lamin-x. I also filled the always on pin-hole light with Lamin-X and the OEM foot-well lights.
If you don't have factory LEDs or if you do and want to replace the bulb anyway you can use these which are cheap and good accessory bulbs.
Use this bulb if you DO NOT have factory LEDs
https://www.amazon.com/Cutequeen-4P...=1519227017&sr=8-6&keywords=cutequeen+red+led
Use this bulb if you DO HAVE factory LEDs (low profile so the lens/diffuser will fit back on) and want a brighter bulb. This only comes in white from what I see so you will still need to tint the lens with a small square of Lamin-x for a red light...
https://www.amazon.com/Cutequeen-10...=1519227436&sr=8-7&keywords=cutequeen+red+led
If you need Lamin-X go here and find the cheapest universal sheet of the color you want.
https://www.lamin-x.com/Universal-Film-Covers-s/1513.htm
Just getting around to checking the links and the two Amazon links for the bulbs are broken.
I also checked out diode dynamics and I find the map lights easy enough, but the dome light is a 578 and they don't have that one. I tried to find the equivalent of the 578 in an LED bulb, and I think it's the 44mm, but not sure if that's the one or not.
Sent from my SM-G950U using Tapatalk
SitKneelBend
St. Louis
3.6 Pentastar
Links fixed...
Here is the dome light to.
Cutequeen Trading 4pcs Red 600 Lumens 5730 12-smd 42mm(1.72") 12v Festoon Dome Light LED Bulbs 211-2 212-2 569 578 - Red(pack of 4) https://www.amazon.com/dp/B016UB93MI/ref=cm_sw_r_cp_apa_BBxKAb0K20TKZ
Don't be put off by the low prices. These are not "cheap" lights..everyone else is just charging too much. I've used these for three years now without a single one failing yet and if they do you'll have plenty of spares. Probably enough to do your buddies truck and your significant others vehicle too.
Odin
Arizona aka HELL
Hemi 6.4L
Links fixed...
Awesome, thank you!
MarshRam
2014 SLT 4x4, 2012 ST
How many washers are necessary to make that work. I need it raised for my speaker box, but the fold down option would be a nice perk as well.
SitKneelBend
St. Louis
3.6 Pentastar
There is a thread on it. For some reason, I went over 3/4" and still couldn't get it to fold down. Conversely, you can cut down the nylon and metal hooks on the back of the seat to accomplish the fold down without raising. Or you could do a combination of both.
http://www.ramforum.com/index.php?threads/6980/
Edit: the above link starts in 2011. Their were changes for 2013+ trucks to the rear wall hooks and latches. Look for posts/threads for 2013 and later trucks...
MarshRam
Thanks, finally found the vid that shows it all. Might have to carve out some of my sub box to for the front bolts, otherwise the box will just rest higher and I still may not get my seat down all the way. Geesh, guess I'll get a six pack since this could be an all dayer!
BTD07
2017 Laramie
Bought this for inside my armrest console for less than $15.00
https://www.amazon.com/gp/product/B01MYAFQM4/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Bought this to hold my phone when using it for navigation. It clips on the dash right in front of the steering wheel. I remove it as soon as I get to my destination.
https://www.amazon.com/gp/product/B075XMG4MX/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Might I sugges these? I have liked mine quite a bit and with the bench seat (not sure about yours) when I lift the console nothing falls out of place or rattles
https://www.amazon.com/s/ref=nb_sb_...er+ram&rh=n:1064954,k:ocd+organizer+ram&ajr=0
Addicted2fishing
Durham region
HEMI 5.7
You’re a genius ! Ha ha ha. Ive struggled with my OCD and the crap rolling around in the arm rest storage ! Thanks!
Is yours bench? To be honest I have never lifted mine but in case I do will the stuff just fall out ?
BTD07
2017 Laramie
Look at my post underneath his..
jmh288
Chicago
2018 (2017 1500 KIA OCT 2017)
I also have both of the Vehicle OCD organizers. They should come from the factory. A must have.
Sent from my iX using my iThumbs via Tapatalk
R.L.K.
Bristol , Tn.
OasisNinjaBat
