XXSNOTRODXX
hey guys, Just did a set of bilstein 5100's on my 2011 ram 1500 sport 4x4. Set at 2.1" (not maxed). I heard alot of story's about front end vibrations in 4x4 when set to max so I decided to go with 2.1" to limit the chance of issues.
Well,everything is installed correctly. Rides great,looks great. except when I engage 4x4 I get not a vibration so much as it is a harsh "wobble" in the front end especially during acceleration. and if you try to turn the wheel you can hear what I am sure is the cv joint binding/locking up. I only put it in 4x4 for a few moments long enough to check it out after the install and that is what I found and then put it back in 2 wheel. NO GOOD.
I have NOT yet had an alignment done. Standing in front of the truck and looking at it you can visibly see that both front wheels each slightly kick out at the top/in at the bottom....so I am sure it needs an alignment. My question is.....do you think the issue I am having is due to not yet having it aligned?. And do you think the alignment will cure the issue?.
To look at the cv axles themselves they do not appear to be at THAT steep of an angle. and I didnt even max the struts out. guys max these struts out and the majority don't complain of any vibrations let along a wobble or a bind.
Any input would be appreciated, thanks in advance!.
